Old 05-11-2011, 11:55 PM
Question TLT Axle Question
I've read the thread on Front Axle Options and it is full of great info. Current project - IH 350 Payhauler - has been delayed slightly to consider an alternative front axle size. I bought the RC Channel standard width axles based on truck measurements taken off a photograph. Now that the frame is built, the axle measurements were a bit off - I could make the RC axles work but would have to recess the spindle deep into the back of the wheel assembly - with possible steering knuckle interference.
So the question: what is the kingpin to kingpin distance on TLT axles? Total axle width is good, just need to know where the kingpins would be.
Thanks!
Old 05-12-2011, 07:27 AM
Car5858's Avatar
Car5858 Car5858 is offline
Default Re: TLT Axle Question
5.4085 in 137.38mm
2.8265 from pinion cp to left kp
2.5820 from pinion cp to right kp
HTH
Old 05-12-2011, 08:40 AM
Thumbs up Re: TLT Axle Question
Thanks for the quick response! This helps with my decision about which axle to go with.
