Old 06-30-2011, 06:26 AM
el barto's Avatar
el barto el barto is offline
el barto is on a distinguished road
Default Mercedes Benz Actros 5 axle end dump truck
Hi guys
here's my next project, which is still at the beginning
after i bought a liebherr l574 wheel loader i decided to get a dump truck as well.
after calculating and thinking that this will be extremely expensive i went online and found a great auction....
a mercedes benz actros 4 axle end dump truck with tamiya chassis and a bruder body. when the car arrived i was really shocked about the awful quality of the truck.
i threw away the following stuff:
dumper
body
chassis
servos
amm
well, the only things i could keep where the axles, the transmission and the spindle drive with the motor....
so i decided to completely overhaul the truck with 5 axles, middle axle is a lifted and steered pusher axle
this is how it looked when arrived (after i already lengthened the chassis and added a 5th axle)
well, i started to find a good original truck which i will shrink to 1:14.5 :-)
this is it. i like the color scheme and all the checker plated aluminium on it. i also get lots of support of the owner of this truck, got about 100 pics on my computer :-)
after buying a new body and mounting it on the chassis
i started on building the fenders based on the original
2nd axle
rear fender before beveling
and after beveling
some first detailing
then i went on the fuel tank
here's the original:
and mine:
the body i got is a mercedes benz actros MP1, the first issue, meanwhile, they had 2 facelifts and i'll have to modify to mp3 myself. especially the front bumper, head lights and the grille are different now.
here's a pic of the originial bruder body
this is how i should look at the end
and this is the situation at the moment. i'm still not sure how to build the 'winglets' on the top sides of the grille...
will be continued
Old 06-30-2011, 08:29 AM
sneaky-pete's Avatar
Master A-Modeler
Default Re: Mercedes Benz Actros 5 axle end dump truck
Nice work....glad to see you over here!
Now get back to work on that beast!
Troy
Old 06-30-2011, 08:50 AM
el barto's Avatar
i'm still to sick of my beast pete......
Old 07-01-2011, 12:22 PM
Azorean Azorean is offline
Azorean is on a distinguished road
Looking great...
Old 07-01-2011, 06:05 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
I think the winglets will take a few pieces of plastic to make. I'd make it with sheet and square or round rod depending on the angle and then use the dremel shaping tools for rough cut then lots and lots of hand shaping with files for profile. Looks great so far!
Old 07-01-2011, 09:02 PM
cbazq271 cbazq271 is offline
where did you get the material to make the fenders and gas tank? Is it real metal or plastic?
Old 07-02-2011, 12:21 PM
el barto's Avatar
this is from wedico, they sold some alu checker plates 1 meter in length and 30 cm in width, but it's not available anymore in this size, only 30x25 cm i think
yes, it is aluminum, but extremely soft, about 2mm in thickness but you can cut it with a big scissors....
Old 07-02-2011, 08:31 PM
thanks, I will try to find some
Old 07-04-2011, 04:50 PM
el barto's Avatar
the small ones can be bought at the wedico site i think.
there's another shop in germany who sells different styles of aluminum checkered plate. www.knupfer.info
now, the time arrived, where hours of work are made and hardly no visible progres is done....
battery case and other small details took me almost 7 hours of work. what you see is about version 3.2 :-)
it's not completely similar to the original, i the weelbase is not correct, but it's too late to change now.
the ad blue tank
another detail
here's a view from the top
today, all the servos, the motor and the esc arrived, will try to find some space for all those parts tomorrow...
best regards
sascha aka el barto
don't forget to vote for the build of the month, the guys appreciate the respect on their works
Old 07-21-2011, 07:26 PM
el barto's Avatar
hi everybody
it's time for another update...
finally i managed the whole steering, lift axle problem....
the 2 first axles share one servo, the proportions of the steer angle fit quite ok...
the 3rd axle, the lift axle has a separate steering servo. there, the servo way will be adjusted with my new radion, a brixlcontrol
the axle will be lifted with a micro servo with 1.8 kg of torque. it's not a direct lifting mechanism, i made some deflection pulleys. the during of lifting and lowering is about 6-8 seconds. if the axle is lifted, this one is not steering anymore.
here's a pic of the pulleys. the shabby string will be replaced through a stronger one
then i did some more scratch building. the air filter, based on the original as well took me 6 hours of work and contains poly, wood and brass....
well, of course, there will be quite a lot of sanding, but i'm quite happy having some sort of result, finally
here's the original, mine is much to small, did some missmeasurements, but it's got one at least :-)
best regards
sascha aka el barto
Old 07-25-2011, 12:48 AM
kyleandtavion kyleandtavion is offline
kyleandtavion is on a distinguished road
Nice fabrication
Old 08-25-2011, 11:34 PM
i like the idea for lifting the axles
great detail work.. i don't have that kind of patience.. lol
