Old 09-08-2011, 02:32 PM
Default Need some bolt help.
I'm wanting to replace the machine screws on the frame work of my Wedico with cap screws (bolt heads). I need 2mm diameter, at least 6mm long and stainless steel. Every time I go to McMaster-Carr I get more confused and I don't want to buy bolts I have no use for.
http://www.mcmaster.com/#
Can anybody point me in the right direction please?
Old 09-08-2011, 03:41 PM
Brian in PA's Avatar
I'd rather be truckin'
Default Re: Need some bolt help.
Craig I went through it, and it seems that the hex head aren't available in metric sizes.
Old 09-08-2011, 03:43 PM
Ken Orme Ken Orme is offline
I looked at McMaster and I did not see any machine screws that small.
I checked "Micro Fasteners" They have the size you are looking for BUT they have a socket head (requires an allen wrench)
A 2mm is .0787 dia. A standard US #2 is .086 dia. If you want to be adventitious you might be able to tap the holes with a #2 tap. I have seen a lot of #2 x 1/4 long brass hex heads in hobby shops.
You might look across the pond for the metric sizes.
Old 09-08-2011, 03:57 PM
Look here----
http://www.microfasteners.com/catalo...cts/MSCHBS.cfm
Or Here
http://www.scalehardware.com/threaded-hex-bolts-c-1
See if you can figure out this site. This is the place I found .040'' rivets for my dragline in qty at a fairly reasonable price.
http://www.chronos.ltd.uk/acatalog/S...___Screws.html
Old 09-08-2011, 05:51 PM
Smokin Joe's Avatar
I use http://www.rbmotion.com for small hardware.
Old 09-08-2011, 06:41 PM
spudd spudd is offline
I get mine from micro fasteners
Old 09-08-2011, 06:50 PM
Well poop, guess I just paint the screws to match the frame. Sure thought it would have been easier than that.
Old 09-08-2011, 07:26 PM
Car5858's Avatar
Car5858 Car5858 is offline
Try these Claus
http://www.microfasteners.com/catalo...ts/METSCMS.cfm
part # SCMS2006
Old 09-08-2011, 07:35 PM
androiduk androiduk is offline
androiduk is on a distinguished road
Just done a search via my search engine .
http://www.boltmeup.com/m2-x-8-stain...20-11201-p.asp
Can tell you nothing more sorry.
The day we stop learning is the day we die ! !
Old 09-08-2011, 08:03 PM
Thanks guys!
