Old 09-23-2011, 06:14 PM
carp carp is offline
Default Morpower Hydraulics?
Seen these on ebay for a while now and just checked the website http://www.morpower.com.tw , anyone had any experience with this? a google search shows people on scale4x4 saying the motor is no good and burns out if its run for to long but surely this can be got around by swapping it out for a brushless?
Old 09-24-2011, 06:20 AM
Default Re: Morpower Hydraulics?
valve block looks close to what's in my 966. Motor looks to have a gear reduction before the pump.
most likely using a larger gear within the pump and therefore needed to slow the RPM down to a usable rate.
Old 09-24-2011, 04:29 PM
so do you think its worth a try?
Old 09-24-2011, 05:24 PM
Can you get any info from the seller, like:
flow per minute with what diameter flow line
max pressure either in Bar or PSI
is it designed for continuous operation or just intermitent use
Old 09-24-2011, 06:08 PM
Blender's Avatar
Blender Blender is offline
the stand alone pump says it's 20.6 bar and for use with 2.5 mm ID tube.
Old 09-24-2011, 07:31 PM
well depending on Price I might just be the guina pig on the valve I just Emailed them so we'll see
Old 09-26-2011, 01:02 PM
Just got a reply from the ebayer seller, i asked could it be used for continuous use in an excavator and this was his reply,
Thank you for your interest for Morpower products.
The cost for the pump is USD$ 129,and shipping cost is USD 19.
It can be continuous use for sure, you can set this in excavator.
Old 09-26-2011, 09:30 PM
dirtpusher9's Avatar
Moderator
Wow, you can't beat that price, if it will hold up. Good find. What are the valves priced at? If this stuff is worth a darn, he is fixin to be really busy.
Old 09-27-2011, 07:48 AM
titandigs's Avatar
Aussie Fabricator
yes I to would be interested in the results of the spool valves, $94 is a good price if they work well
Old 09-29-2011, 07:18 AM
Haven't these been for sale for quite some time now? If you look at the feedback on MORPOWER they only have 4 one of them takes you to all the ebay listings for helicopter related items. Steve,And you said they are one month out on first production run. HMM, I hope there's more feedback on this item to convince me. Once you have one just measure it and make your own valve with as many valves you require.
Just my 4 cents.
Old 09-29-2011, 06:07 PM
Just my 4 cents.
Steve , I'm not waiting I'm going to the savage yard on sat to get mtrl. I'm gona look for some brass blocks .
Old 10-03-2011, 09:38 PM
Well I'm ready to cut my 1st 1 it's drawn up as a 3 spool but I can add or subtract . I'm going with alum for now so we'll see now to get the time
Old 02-18-2013, 12:04 PM
FlyingBeagle's Avatar
So did anyone ever take the plunge and try these guys products out. I was curious if they were worth a darn???
Old 02-18-2013, 12:08 PM
I bought one and took it apart and was very impressed with the internals very big gears. Ed
Old 02-19-2013, 07:14 AM
Michael S Michael S is offline
Michael S is on a distinguished road
Im running the 3 valve block in my excavator servos are crap but fair work on the rest
