Old 09-30-2011, 08:43 PM
rc_farmer's Avatar
Master Builder
Default JD 8320
It's never too early to start testing your equipment for spring planting. Just finished redoing this one. Enjoy!
Giving up is not an option!!!
Old 09-30-2011, 11:41 PM
hauler_10-4 hauler_10-4 is offline
hauler_10-4 is on a distinguished road
Default Re: JD 8320
Great job Rob.
Old 10-01-2011, 12:52 AM
Default Re: JD 8320
Very nice video, and nice work on that JD, Rob. I like the working 3 point hitch. Is it servo operated? If so, how much torque does a servo need for lifting something like that planter?
Old 10-01-2011, 02:19 AM
Default Re: JD 8320
Looks great! I´ve got teh same planter...
Could you show us more about the tractor? Hitch, Transmission, ....?
regards,
Frank
Old 10-01-2011, 01:01 PM
rc_farmer's Avatar
Master Builder
Default Re: JD 8320
I will take some pics of the innards and post for ya. I used a Tamiya gearbox driving a wedico diff. Had to do a lot of shaving on both the diff and the tractor to get it to fit.
Old 10-01-2011, 12:58 PM
rc_farmer's Avatar
Master Builder
Default Re: JD 8320
Nat, I used a Hitec 645MG....it is place under the seat. At 4.8v, it has 107in oz of torque. I don't know if i over kill it, but i also use a CC bec to draw more power directly to the servo. Now it doesn't kill the spd ctrl'r when lifting the planter.
Old 10-01-2011, 01:19 PM
Default Re: JD 8320
Looking forward to the photos. I always wondered how well a semi rear end would fit in a row crop tractor, after they became so popular for the articulated tractors.
Old 10-04-2011, 10:08 PM
rc_farmer's Avatar
Master Builder
Default Re: JD 8320
Here are some construction pics
Old 10-05-2011, 02:51 PM
Default Re: JD 8320
Great conversion! Do you still have the differntial in the rear axle?
regards,
Frank
Old 10-05-2011, 11:58 PM
rc_farmer's Avatar
Master Builder
Default Re: JD 8320
Yes the diff is still in there.
Old 10-05-2011, 05:31 PM
Default Re: JD 8320
Wow, that's a whole lot of mechanical and electrical equipment, crammed into a really tight space! Impressive, but it doesn't look very easy to do! And you are still able to keep the cab interior; is there anything you can't convert to RC?
Old 10-06-2011, 12:06 AM
rc_farmer's Avatar
Master Builder
Default Re: JD 8320
Nate, its not too bad of a conversion. After these pics were taken, i remove more of the metal from the tank area to fit the ESC in better. The tractor fits back togethe very well. I had to take some area out the bottom of the cab, but the upper area is all intact......can't see any wires.
I'll post some of it reassembled tomorrow.
Thanks for taking a look.
Old 10-07-2011, 01:24 AM
Default Re: JD 8320
Thanks for sharing Rob. I see a lot of guys who don't share their secerts, when it comes to these die-cast conversions, and that's not you. You truly are promoting the hobby.
Old 10-16-2011, 10:40 AM
Default Re: JD 8320
wow that is a tight fit for the running gear.
