Old 10-11-2011, 08:03 PM
Red face s&f + DOC for a .010 endmill
just checking to see what you all that have done this your whole life think
For DOC I'm thinking .005 Feed rate @ 1in/min s. speed @ 4500 rpm .
to fast , yes / no ?
Old 10-11-2011, 08:57 PM
CrimsonCorsair's Avatar
Default Re: s&f + DOC for a .010 endmill
was any of that english????
Old 10-11-2011, 09:00 PM
OK so ya need a legend
S&F = speeds and feeds
DOC = depth of cut
Old 10-11-2011, 09:04 PM
thanks -- now I know what I don't know
Old 10-11-2011, 09:13 PM
pugs pugs is offline
Greatly depends on the endmill. If its a short stubby and well supported you're probably on the slow side. I've played with some small bits before and even my 10k rpm spindle is too slow
Jeff
Old 10-11-2011, 09:30 PM
it's from Frank Mari .010 dia 2 flute sqr Miniature Carbide Finisher .03 L.O.C I broke 1 just putting it in the collet droped out of my clumsy hands
Old 10-11-2011, 09:38 PM
Coolant or dry and what material? DOC and s&f don't sound to bad.
LYNN
Old 10-11-2011, 09:43 PM
Lynn , coolant , 6061-T65 alu
I'm just trying to get over the braking phobia
Jeff I got a little ingraving to do on the haul truck hubs If it take 3 hrs while I'm doing something else , I don't care
Been there done that. Just hold them the wrong way and they break.
I've gotten some small mills from Harvey tool, seem to have a failry large selection and you can get the minimum length of cut that you need to get the strongest possible. Mari has good stuff too.
Whats you're Axial engagement? if that is tiny, can probably up the DOC a bit
Jeff
Old 10-11-2011, 10:43 PM
I run 90deg single flute engravers with .005 tip to depth of .010" to .015" at 10k rpm and 15ipm feed, 30ipm plunge in 6061 if that helps at all
Jeff
Old 10-12-2011, 09:35 AM
thanks Jeff & lynn I'm going to give this a try
Old 10-12-2011, 07:50 PM
well you tell me
Old 10-12-2011, 08:52 PM
Looks sharp
Jeff
