Old 10-15-2011, 07:39 PM
andi4x4 andi4x4 is offline
andi4x4 is on a distinguished road
Default servo mods
Hi Guys,
I have links for modyifyng servos for continuous running, but, I was wondering if I could get two servos to run in opposite directions, indepenently, on one channel ? I was thinking that a diode in the signal wire would only let a servo run from neutral/centre to one side, but, not the other ? Or have I got my understanding of servo electronics wrong ?
Andi
As I get older I find myself thinking about the hereafter - I go into a room and then wonder "what am I here after ? " !.
Isle of man - 70,000 alcoholics clinging to a rock in the middle of the Irish Sea !
Old 10-15-2011, 09:15 PM
Default Re: servo mods
http://www.google.com/products/catal...d=0CEYQ8wIwAw#
http://www.youtube.com/watch?v=EK_FdRTenl0
See if these link's will help!
Later, Neil#2 aka doodlebug.
Old 10-15-2011, 11:17 PM
Hi Neil,
Thanks for the links - not quite what I am looking for, but, very usefull to know anyway !
Andi
Old 10-15-2011, 11:25 PM
Just found this on the net - http://www.servocity.com/html/180o_servo_stretcher.html - A pair of these running off one channel would do exactly what I am looking for when set up right !
Andi
Old 10-16-2011, 04:55 AM
Andi:
If you can go inside to do the mod, you can just reverse the power leads to the servo drive motor on one of the servos.
This is the way we used to make reverse-rotation servos before they started putting switches on the Tx's. Was cheaper than paying 50% more for a specially purchased 'reverse-rotation' servo.
WhiteWolf
- w/ close to 30 years in the hobby, and lotsa tidbits in the grey matter.
Old 10-18-2011, 03:46 PM
Hi Whitewolf,
I have done the reversing mod before in the past - I too have close to 30 years RC experience - for my sins !
The link in my last post points to a device which would allow me to connect two servos to one channel, and, with the available adjustment on the device, would allow me to set one servo to run from neutral to full left throw, and set the other to run from neutral to full right throw - this would allow me to control two seperate mechanical functions from one switch on the Tx - one for fifth wheel latch/release ( only require movement one side of neutral ) the other for anything only needing one side of servo throw - i.e latch switch for lights on/off.
Andi
