Old 10-16-2011, 02:49 PM
Question Dumb Question About Double Square Headlights
I have a set of the PMD Double Square Headlights, do you just epoxy the turn signal lenses on the end? Doesn't seem right to me but don't see another way. Also I assume the smooth side goes to the outside but this would mean the epoxy is really only holding on the high spots of the jeweled side. Nothing about this seems right to me, need help.
Old 10-16-2011, 03:01 PM
Stylin n profilin's Avatar
Stylin n profilin Stylin n profilin is offline
I'm tryin Boss!
Stylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura about
Default Re: Dumb Question About Double Square Headlights
Hey Craig..I put the smooth side to the light with ca glue..It seems to hold up well..I haven't any problems with them..better holding area..i didnt like the gap it made..
One Bus Stop Short Of The Short Bus...
Old 10-16-2011, 03:02 PM
Thanks John, I knew there were many of you guys that had been down this road.
Old 10-16-2011, 03:05 PM
I'm tryin Boss!
yup...its not bad..I just didnt like the way they sat..unless you want to try to sand the smooth
Old 10-16-2011, 04:54 PM
Snowman's Avatar
Snowman Snowman is offline
Unless you get some thick transparent plastic like from a spare cd case (smooth part) cut to shape and glue that on and then paint it with some tamiya clear orange? Just an idea.
Nick
My Peterbilt build thread:
Old 10-16-2011, 07:02 PM
Brian in PA's Avatar
I'd rather be truckin'
Craig I CA glued the lenses with the points in. I have done this on my last 3 builds with no problems.
