Old 11-07-2011, 10:47 PM
Rebekah_harper Rebekah_harper is offline
Rebekah_harper is on a distinguished road
Default Digger buckets
Hiya,
I just wanted to share the bucket I made.
Am enjoying working with aluminium.
Old 11-07-2011, 11:34 PM
RCLogger's Avatar
RCLogger RCLogger is offline
Default Re: Digger buckets
WOW Great job with the aluminium, did you weld that together ?
Keep up the great work !
Greg
Old 11-08-2011, 05:23 AM
Hiya,
Thank you.
I do aluminium bonding now. The grading bucket was brazed with durafix.
The unfinished one is going to be a heavy duty bucket.
I making them for a new friend who is lending me his digger so I can install and make a thumb for him.
Old 11-08-2011, 06:53 AM
Fabulous fab work Bekah.
Old 11-08-2011, 09:34 AM
Very nice & clean work.
Old 11-08-2011, 09:45 AM
Ken Orme Ken Orme is offline
Bucket looks very good.
What is durafix?
Where did you obtain it?
Is is similar to J B weld?
Old 11-10-2011, 06:27 PM
Durafix is a brazing material with a flux imbedded.
Doesn't need a lot of heat and is very strong. You can find it on YouTube.
Just needs good prep of material.
Old 11-10-2011, 08:13 PM
dirtpusher9's Avatar
Moderator
Nice work on your buckets.
I checked out the Durafix product, that stuff looks amazing. Is it as easy to use as they say? Where do you buy from?
Old 11-11-2011, 01:48 AM
Dreamweaver's Avatar
Weaver Of Dreams
Hey Becky How's things going... The bucket looks great, But I would not expect less from you.
Mike "DREAMWEAVER" Johnson
Old 11-11-2011, 08:59 AM
I've used the Durafix aluminum brazing product on my International PH350 truck frame and found it works just as in the video. My frame is much heavier than the soda can shown, so it does take longer to heat up. As long as the base material is just at the melting temp of the rod, it works great. I had to braze areas about 7" long, so had to keep the heat ahead of the brazing area, but worked fine. Caution: if brazing small or thin parts, it is easy to overheat and melt the base material - about 715F degrees for the rod, about 1050F degrees for the base. I liquified two small rollers before learning, but am a convert. Excellent product and very strong. Got mine at Tractor Supply.
Old 11-11-2011, 01:04 PM
That's a nice bucket, for sure. Durafix sounds interesting. Might have to check that out. It's nice when you can assemble something like this without screws and tapping small holes. It just looks more realistic and scale when you can weld or bond metal together.
Old 05-30-2012, 04:20 PM
Well that's me back from Oman and into the shed.
Got these made, not completely finished but 3 nearly there.
Old 05-30-2012, 05:06 PM
apfubar apfubar is offline
Lookin good!
Old 05-31-2012, 02:11 PM
FlyingBeagle's Avatar
They sell a version of Durafix at Harbor Freight as well. I think it is called something different, but it is the same stuff. Works great, but as was mentioned above Cleanliness is the key.
Old 06-08-2012, 08:28 PM
Just another update.
Grading bucket to which I added a front lip.
A trench bucket which is pretty much finished just some tweaks.
Old 06-09-2012, 09:19 AM
kerst's Avatar
kerst kerst is offline
Very nice!
Kerst
Old 06-17-2012, 02:59 PM
Just some more.
Here are two of the buckets finished
These two are getting there but the skeleton buckets is tedious. Am enjoying it though.
Old 06-20-2012, 04:22 AM
caterpillar caterpillar is offline
caterpillar is on a distinguished road
excellent work Rebekah! I am impressed about the way you weld the alu. Is durafix not hard to use on such small objects? When you are welding the second side of the bucket, is the first side not coming apart while the bucket is being heated again? how do you hold the sides into position?
