Military Vehicles. Trucks/Support Vehicles in here. |
![]() Well with the truck goes the trailer so here goes the hacking of 2 new bruder drop decks and turning them into a sort of HET looking trailer to haul are tank with.. So 2 new trailer.. ![]() First 2 cuts the tape gives me a stright line to follow.. ![]() WALA ![]() Next onto the 2nd trailer one cut. ![]() Then one more to shorten the deck. ![]() Then all 3 back together but I have to reconnect the bracing still but here is how it looks. ![]() ![]() Now since the truck is a 1 5/8 taller than a stock semi I need to make a new neck for the trailer. I am going with the set up the HET M1000 has with a bending point at the front of the trailer that the neck hooks too. Also the neck will be made out of 1/2 plastic sheet.. ![]() More tomorrow if I get a new band saw blade ![]() Thanks Much for looking..
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Looks good so far
![]() If you need a drawing of the goose neck send me a pm. Carl |
![]() Quote:
Nah not going to worry about making them steer there will never be enuff eight on it to have a problem turning just more making what he wants..
Great project!
Looks great Paul. Can't wait to see it finished.
Paul what is the drive train in this truck like? Are you going to be re powering it? Would be a good rig to put those brass helical gears in.
Thanks Much guys for the great comments..
Claus I am not a big fan of them Brass gears I have them in my oil field truck they are a pain in the arse to get set up and then they still shift hard and they are noise and I have a ton of good old JD black grease in there that helped it to shift better and got rid of some of the noise but not enuff. I have one more tranny built with them and I have not used it yet just not real happy with them.. We are running a stock trans with a Wheely King T-case..
nice trailer what did you use for a frame? and what color are you going to paint it? cant wait to see more
SHANE... Member of the Central Plains Mini Truckers.. |
Hello Tamiya cowboy
As a newbe to this field, could you tell me where you got the two trailers for your M1000 build ? Thanks George |
In his first post it mentions what they are: Bruder drop deck trailers. Check out www.Brudertoys.com
Well with the truck goes the trailer so here goes the hacking of 2 "BRUDER DROP DECKS" and turning them into a sort of HET looking trailer to haul are tank with..
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by scalelover; 03-17-2012 at 06:47 PM. |
Thank`s for the link.
George Keep the pictures coming please. |
We are waiting on parts so as soon as I can get them we will be back on it.
What a great idea for a project! Too bad I already spent $300.00 on a new controller to return to racing or I would have jumped on a truck with this in mind.
Can't wait to see more! ~ Jeff |
Vids of the whole thing married together & running?
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests) | |
