Old 12-06-2011, 05:27 AM
pigeonfarmboy's Avatar
Default PFB Tri-Axle King Hauler
Need something to tug the 850D around. Got the rails cut/drilled/tapped tonight and got it in roller form:
Went with Russ's new airbag suspension. Super nice stuff and makes it super easy to link up multiple axles.
Had the regular roadys so I was excited to see the wide guys come out:
Plan to try it 8x6 first, if needed I'll drop in a TLT up front. Plan to use a Holmes Hobbies puller on either a 3-speed or an HD RC4WD R2 trans. Been using their "Mega Truck" drivelines on the dump with no issues. Pricey but they will hold up a good while. Will eventually mod the body to a pete as well. Still unsure on daycab/sleeper.
Old 12-06-2011, 09:59 AM
Default Re: PFB Tri-Axle King Hauler
Looking good Nate.
The 850 will certainly be the ultimate for a durability test on Russ's suspension components!
Tri drives... wide turning radius, if it turns at all! You americans don't use jeeps?
Old 12-06-2011, 04:22 PM
Looking good Nate.
Maybe I don't drink enough maple syrup...what's jeeps got to do with it?
Old 12-06-2011, 05:43 PM
Looking good Nate.
Jeeps are for mud boogin Joe , A co . down hear moves a 385 cat with a triaxle tractor and a 5 axle trailer .
looks good Nate . you might want to center the 5th wheel over the 2nd rear or make a sliding fith wheel . If your building your own trailer make the neck long .
(edit) here you go http://www.trailking.com/trailers/?trailer_id=45
Old 12-06-2011, 06:41 PM
Nice truck, starting to look like Freddy's black 8X6. I know this is getting the cart before the horse but what are you going to have for a lowboy?
Old 12-06-2011, 09:17 PM
Looking really good, she is going to be a heavy hauler for sure.
I'm waiting on a set of russ's suspension myself, and can't wait to get them.
Keep up the good work.
Old 12-06-2011, 01:47 PM
Great looking truck, so far! I really like Russ's suspension too. The nice thing is you will be able to tune it's capacity, with heavier springs, if you want. We are really lucky to have some great vendors now, right here in our own part of the hemisphere.
Hmm, so let's see. 80 pounds spread over 6 axles (not counting the steering axle) would be a bit over 13.25 pounds per axle. Add the weight of the truck and trailer itself, and it's probably going to go up to 18 or 20 pounds? That's heavy hauling!
Old 12-06-2011, 09:19 PM
Looks good cant wait to see more but steve is right you should have the plate set over or ahead of the center axle..
Old 12-06-2011, 09:48 PM
Noted! 5th isn't mounted yet.
I have Izzys old tandem lowboy I may try to extend it but will probably just build a new one
Old 12-06-2011, 09:53 PM
Looks like you are off to a great start Nate it should look real good pulling around the excavator.
Old 12-06-2011, 10:12 PM
That s right I forgot you got that from Chris.. Great trailer it will all look great together..
Old 12-06-2011, 10:32 PM
That trailer is real nice but it would look all wrong with that monster on a tandem low boy.
For instance here's what pulls a stripped down Zaxxis: http://www.coesens.com/fotoboek/imag...20x%20642).jpg
Old 12-06-2011, 10:37 PM
Nate , you may be able to just build an extension to the gooseneck that flips down . I've seen a real 1 like that somewhere in my travels
Old 12-06-2011, 11:59 PM
Hey Steve like this? Flip over neck http://www.xlspecializedtrailer.com/...rn-Canada.aspx Full Jeep picture, http://www.xlspecializedtrailer.com/...lti-Axles.aspx
Later, Neil.
Old 12-07-2011, 07:17 AM
"You picked the 1st one that appeared on google images, didn't ya Stevie?! "
nope I went on trail kings site I guess I could take a crapy pic of a set up I drive by every day . they don't use it much
Old 12-07-2011, 07:23 PM
spudd spudd is offline
Are you going to send it to Freddy to get the bubble wrap paint job??????????
That way it will match your dump!!!!!
RIP FREDDYGEARDRIVE
Old 12-07-2011, 07:50 PM
Stylin n profilin's Avatar
Stylin n profilin Stylin n profilin is offline
I'm tryin Boss!
Stylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura about
That's looking awesome Nathan..i cant wait to see how this turns out........I think i see my baby in the backround..
One Bus Stop Short Of The Short Bus...
Old 12-07-2011, 10:12 PM
Ahahaha low blow (it's still like that......cause I'm lazy as ****)
Old 12-08-2011, 12:54 AM
russisloud's Avatar
wow, that frame is clean as far as i know this is the first tri-axle to use my "air ride" the truck should look killer when its done
Old 12-08-2011, 08:40 AM
rc10johnny's Avatar
rc10johnny rc10johnny is offline
rc10johnny is on a distinguished road
Hmmmmm,I believe you have a Tri axel.....don't ya
