Old 12-09-2011, 11:27 AM
CustomClod CustomClod is offline
CustomClod is on a distinguished road
Default 12 channel radio and high torque motor question
Hello all. I have a 9 channel Futaba radio that has the 2.4 ghz reciever and i need to upgrade to a 12 channel radio and the corrseponding 2,4 ghz reciever. I guess my question is whats a good set up to use? I'll be using it on my rotator truck and i dont have enough channels to build a wheel lift or the out riggers.
Also what low torque motor is a good motor to run? The truck will be heavy and need all the low speed and torque it can get.
Thanks for the help.
I run a single stack Mack with a dump body on the back!
Old 12-09-2011, 11:53 AM
pigeonfarmboy's Avatar
Default Re: 12 channel radio
I'm partial to JR stuff because I've never had any issues with it. The 12X is the nicest radio I've laid my hands on. Magnesium frame and really solid feel. The 4 proportional knobs are probably gonna give you much better control options with your truck. Price is similar to the Futaba 12ch. Since you already have a Futaba rx you may want to go that route. Guess it depends how many you have.
Old 12-09-2011, 12:22 PM
Default Re: 12 channel radio and high torque motor question
Do you have a link or web site i could check out? Thanks
Old 12-09-2011, 12:35 PM
I run a Futaba 12FG. I like it a lot. Not as cheap a some options out there, but it's very programmable, and you can set it up for any model. Your bound to get a lot of opinions on this question, because everyone has their favorites. I used to be a HiTec fan, but after going all Futaba radio gear, I have been extremely happy. Never a glitch or problem binding the receivers, and always reliable. I've run Futaba gear on everything from my nitro helicopter to my rock crawlers. The 2.4 giga-hertz receivers aren't cheap (for each model you want to run), but you get what you pay for.
Old 12-09-2011, 06:04 PM
JensR JensR is offline
If you are not using all channels at the same time, you can just switch a bank of servos off and another one on. Problem is that your trim and endpoint adjustment will be shared between both banks.
If the functions are only on/off (outriggers in or out, axle up or down), you might get away with even simpler stuff.
Old 12-09-2011, 08:16 PM
Agree with Nathan, it's all preference. Can't go wrong with JR or Futaba. Wish US r/c consumers had more choices but that's it if you ever plan to have your gear serviced.
http://www.horizonhobby.com/products...-only-JRP12TXX
For the motor it depends what speed controller and transmission you're using. Telling us the weight of the truck would help too.
Old 12-10-2011, 12:02 AM
Thanks for the link and the info guys!
The tranny is the stock 3 speed that is in second gear. Not gonna shift. And if i had to gues on weight id say when its all done probably in the 20-25 pound range maybe. Thanks for the help
Old 12-10-2011, 01:06 AM
Why not lock it in first gear if you need more torque and slow speed? You could put a bigger pinion gear on a lathe motor maybe the stock silver can for a little more speed.
Old 12-10-2011, 11:15 AM
First gear with a lathe motor will probably do fine - grab a smaller pinion to get a little bit more. I say this cuase I towed around a 95# dozer on a lowboy at Indy with a stock areomax. (industrial style carpet) with a stock can motor, stock transmission and running an MFU unit. Biggest issue was that the MFU couldn't handle the twim 4500mAh packs I had running it (it would over current shut down).
if it's still too fast or you want to use that three speed - i suggest a gear reduction unit. The RC4WD units that bolt inline are dcent but gear mesh needs to be watched - they don't bolt on to silver cans but I'm told they do OK with aftermarket motors.
A good friend swears by the Integy 4:1 units - I am trying one for the first time myself - they bolt up nicely and you have complete control of gear mesh. My curren tbuiild has the Integy 4:1 and an Integy 55 turn. Lots of power and lots of Torque
The integy is decently compact - due to the layout it will place the motor overtop of the servos on most trucks without moving the tranmission.
Hope this helps ....
Old 12-10-2011, 11:38 AM
Izzy, it's off topic, but did you ever convert that Case IH Quad Trac to radio control?
Old 12-10-2011, 12:25 PM
YEP - twin 55 turn motors - full 4TD - full metal drives and all.
ihbuilder is the present owner.
Old 12-10-2011, 12:38 PM
Sounds very interesting. Never made a thread for it, did you? I remember a similar model being built and documented on Scale 4x4. Was that one your's?
Old 12-10-2011, 12:50 PM
Nate , someday I'll post it up I got it torn down to upgrade the under carriage so the tracks stay on . I got an idea for stronger tracks too . Chris did a good job on it . I want to pull pans with it .
Old 12-10-2011, 12:56 PM
I had a post on Garden not on scale.
I still have all the photos......
http://s262.photobucket.com/albums/i...ifr/STX%20480/
Old 12-10-2011, 01:02 PM
Lies...all lies!
http://www.scale4x4rc.org/forums/showthread.php?t=33567
I spent a great deal of time looking over your thread. A lot of cool ideas to be had there.
Old 12-10-2011, 01:15 PM
I guess I had - I don't remember that .... guess the brain cells are dyin faster than i thought...... maybe it was the bicycle issue???? LOL
Old 12-10-2011, 01:32 PM
"He was a pretty normal guy, until.....you know.....the accident."
Old 12-10-2011, 05:19 PM
Thanks guys. I'll have to check out the gear reduction units. Ill try locking it in first gear and see what it does. I forget how it works... The higher the turn on a motor the slower more torque it has? Thanks
Old 12-10-2011, 10:36 PM
In general that's right..... More importantly for you is more turns is more Torque.
Old 12-10-2011, 11:15 PM
Higher turns usually do make more torque, and spin fewer RPMs. Lower turns have more hp, and less low end power, but spin faster. Turns is basically refering to the number of times the wire is wrapped around an armature pole. A 55 turn motor will have the wire wrapped 55 times. The more you wrap the wire around the pole, the stronger the magnetic field it produces. More turns also increases the internal resistance of a motor, and the more resistance it has, the less current it will consume. That means longer run times, which is always nice.
