Go Back   RC Truck and Construction > RC Truck's Kings of the Road > Australian Rigs & Roadtrains
Australian Rigs & Roadtrains A place for aussies to show off their unique truck configurations.
Old 12-13-2011, 07:45 AM
kenlms kenlms is offline
kenlms is on a distinguished road
Default Dolly trailer build question
Hi all,
I am embarking on my first custom truck project and am building a dolly. I have knocked one up from parts of the Tamiya pole trailer and and other spare bits.
I have 2 what I think are important configuration questions:
1) where should the kingpin sit in relation to the axles? I copied the configuration from a truck kit, which has the king pin just behind the centre of the axle group, but it seem to sit tail heavy on the suspension under load.
2) Should the draw-bar be rigid mounted or pivot where it attaches to the trailer? I.e. should there be any vertical load transferred to the tow hitch?
Thank you for any advice!
Old 12-13-2011, 08:18 AM
diesel950 diesel950 is offline
diesel950 is on a distinguished road
Default Re: Dolly trailer build question
king pin should be in the middle of the axles
and a-frame should pivot
Old 12-13-2011, 05:54 PM
Thank you gentlemen!
Old 12-13-2011, 09:44 PM
Cossett's Avatar
Cossett Cossett is offline
On Leave
Hi kenlms, the other benefits of having a pivoting draw bar on the dolly is when you have a drop deck trailer and a normal trailer and the tow hitch is at a different heights you can connect the dolly with out any hassles.....
Cheers Tracy
Love my Kenworths
Old 03-19-2012, 08:02 PM
Msmaddie's Avatar
Msmaddie Msmaddie is offline
Little miss fabricator
Msmaddie is on a distinguished road
You can do either. All the tandem converters I pull have a pivoting draw bar. But Pepsi has a wack of rigids.
You wanna try and set your converter up so your fifth wheel is centered between the axles. The 1:1 converters are basically just a spring ride suspension. Just like you see on a tandem on a trailer. I have pulled a couple converters where the fifth wheel is located towards the back. But I think that was due to pulling trailers that have a deep pin.
Have a look at my "brass tandem axle converter" build thread. I built on from scratch with realistic working suspension.
