Old 01-21-2012, 08:48 PM
mrxreight mrxreight is offline
mrxreight is on a distinguished road
Default HELP!!!!!!
Imwoundering if any one can help i have fitting the tamiya light kit to my truck and have major problems all the lights work fine if you test then but the you got to drive and the truck will not move if you turn the front wheel the blinkers go mad and the reverse beeper goes off can any please help
cheers ashley
Old 01-21-2012, 10:33 PM
1985 kenworth's Avatar
Default Re: HELP!!!!!!
i'm not sure if you know but when you put install the mfu you have to set it up after you plug everything in and make sure the battery is fully charged in the truck and the radio also if your radio has the manual adjust trims make sure they are all centered if one is off even a slight notch it could be trying to do another function..hope that helps
