Old 01-22-2012, 02:43 AM
Jared Jared is offline
Default 1/16 Bucyrus Erie 25B
After a year of drawing, losing files, drawing again, modifying, tweaking, jiggering, improving, and generally not leaving well enough alone, I'm finally cutting metal. I bought a "new" Clausing 8530 mill a couple months ago and after throwing some money at it I've got it running now, so my first project with it is a B-E 22B. I started cutting metal a couple of weeks ago but didn't have much to show until now.
This is an almost-scale model. I took a few liberties with dimensions and shapes to make machining and buying metal stock easier but on the whole it's pretty close. I don't have a real machine to measure, just a spec sheet with the major dimensions on it. Everything else I've had to guess by looking at pictures.
I haven't designed a boom and fairlead for it yet but it eventually it will be set up as a dragline and clam bucket.
So here goes...
All functions are modified servos. Makes it clean and easy that way. We'll see how they hold up.
Did a bunch of puttering around in the garage and I found these on the mill.
Neither the track frame or carbody is finished yet. Got a bunch of 2-56 holes to drill and tap yet in the track frame and the carbody still needs to be hollowed out underneath to make room for the servos that will drive the tracks.
Hopefully I can keep things going and get this done before summer. It looks like I'll be working a few hours from home for a while so progress updates may be sporadic.
Old 01-22-2012, 05:11 AM
Default Re: 1/16 Bucyrus Erie 22B-III
Look's like a fun project, Thank's for sharing the progress!
Old 01-22-2012, 09:47 AM
Cool build. It will be fun to watch it come together.
Old 01-22-2012, 09:53 AM
Looks like your off to a good start. If you need details of the machine,I can help. I have owners manuals and parts books for the 22B in my vast collection of Bucyrus-Erie memorabilia.
Old 01-22-2012, 01:17 PM
Iron Art's Avatar
Iron Art Iron Art is offline
Jared, good to see a new project started. will be fun to watch it grow. Fred
Old 01-22-2012, 03:29 PM
Brel's Avatar
Brel Brel is offline
this looks like it is going to be a very interesting build to watch
Old 01-22-2012, 04:38 PM
FabOne's Avatar
FabOne FabOne is offline
This going to be an AWESOME design and build!! Keep us all posted with updates.
Thanks for sharing.
-Terry
FabOne
NW Ohio
Old 01-22-2012, 11:22 PM
Thanks, guys! Steve, the only thing I really need is the outside diameter of the swing circle hook roller path. I have a sneaking suspicion mine is too big but I hope not; I have it drawn for 90 teeth on the swing gear which will be really easy to cut on the rotary table without dividing plates. Probably your manuals don't give that, though. Do they have detailed drawings in them with dimensions? If they do I'll just get one.
Hi Fred, good to meet you at the Threshing Bee. Don't let me go too long between updates.
Old 01-22-2012, 11:49 PM
rc_farmer's Avatar
Master Builder
This is going to be an exciting build to follow.
Giving up is not an option!!!
Old 01-23-2012, 06:53 AM
Don't worry about it, Steve. D8R Dan fixed me up with a drawing.
Old 01-23-2012, 07:51 AM
The slewing ring measures 60''dia X 47''dia in the hook roller grooves X 9''thick.I count 64T on the internal ring and it looks to be about a 42'' PD. The pinion appears to be 16T. I don't know how you're going to cut the internal ring though. I have measurements for the A frame and the correct wire rope sizes and lengths. This IS going to be a dragline ,Correct? I can also get you some pictures and sizes of the fairlead in the spring when we have our outdoor show. The books I have show alot of details. Especially the 22-RB books.
Old 01-23-2012, 10:37 AM
A scratch build and a cable machine! My-2-favorite things! I will follow this closely. I'm sure you will put a lot of work and $$ in this project but I am not sure about your decision to use servos for your drums. I don't think they will last. Gearmotors would be a better choice in my opinion but maybe you have thought this thru. Sometimes taking the easy way out will cost you in the end but I wish you luck and keep the pictures coming.
Old 01-23-2012, 11:27 PM
That's great, Steve! You're a gold mine. Turns out mine is a little smaller. It scales out to 56 inches so I can make it bigger which means that the rest of the undercarriage is pretty close. I was worried I might have jumped the gun and started building too soon.
I've got a shaper that once I make a new gib for the table it should be good to go. I traded 20 hours of labor for it. A friend of mine was going to tear it apart to shake his gold separating table and I talked him out of it. The real trick will be to grind the tool to the proper profile. I think I'm going to stick with the 32 pitch 90 tooth gear, even though 24P 60-something teeth would be more scale simply because the bigger the teeth get, the higher the gear ratio gets and the harder the swing servo will have to work. The one I'm using is the slowest low-profile servo I could find and I'll still have to slow it down some.
The A-frame mesurements would be good, too. I just eyeballed it and I think I'm close but measurements can't be beat. Basically I just need to know how far it is from something like the center of rotation or the boom pins, and how high.
It will be a dragline and fairlead details would be excellent. I haven't been able to find any good pictures that show how it mounts to the deck. I know it pins to the boom foot.
I think I'll be ok. At least I hope so. I'm using a pair of servos I already have for the hoist drums. They are Hitech HS-965MGs that are supposed to make 139 in/oz of torque and my drums have a .5 in radius so that means theoretically they should be able to lift 17.375 lbs. I think a bucket full of sand will weigh 2 or 3 lbs so I think they'll hold up. I've already got 6 or 8 hours on them in my other crane and they don't seem to be bothered any. We'll find out. If nothing else, I'll say I'm conducting research for the good of the hobby finding out how servos like this application. The servos have metal gears and dual ball bearings, plus the drums will also be supported by a shaft with two bearings on it.
Old 01-24-2012, 09:02 AM
This should steer you in the right direction.
Not sure if I have the correct rigging for the boom.
There are several fairlead arrangements. This one looks cool because of the side rollers.
Old 01-24-2012, 10:18 AM
JensR JensR is offline
I think that converted servos are really useful and they are basically nothing else than gear motors in a different form factor and packaging anyway?
As long as their gear ratio matches the application - if not then gear motors usually offer a wider range of gear ratios.
I'd love to buy a gear motor with comparable power and double ball bearings that does not cost an arm and a leg. I'd be honestly interested, as I couldn't find one and went with the popular RB35. But these motors only have bushings and these do not take radial loads well, in my experience.
Looks like a great project and the drawings Steve posted are fantastic!
Old 01-24-2012, 02:23 PM
D8R D8R is offline
Here´s the front of my friend 22-RB´s
The boom is made of L-profile, maybee this was unique to machines built in England
Dan
Old 01-24-2012, 08:45 PM
dirtpusher9's Avatar
Moderator
Always nice to see the scratch builds and this one will be another good one. Don't forget lots of pics.
Old 01-24-2012, 09:26 PM
Wow!!!! Thank you so much, Steve and Dan! Steve, you just saved me $60 on a manual I was looking at. I'm not sure how I can repay the favors, but if I see something I can help with, I'll make extra sure I will!
Old 02-01-2012, 04:10 PM
rustybucket rustybucket is offline
rustybucket is on a distinguished road
Hi Jared, Welcome to the elite 'Cable Digger Builders' club . We are few in number but we are growing. I knew that machine well. I built them in the erecting shops in Lincoln 50 years ago. One of the classiest excavators ever built.
Old 02-03-2012, 07:49 AM
Papy Papy is offline
Another Bucyrus on this forum !!! great idea ! Congrat's for the CAD design : this will allow you to build it faster
I know an old man in my area that has at least 2 of them in perfect condition, including lattice boom/shovel/backhoe equipments.....too bad the guy is over 80 and his son is just waiting he's gone to scrap all this old iron
