Old 01-22-2012, 07:11 PM
Default Leimbach pump motor options?
I am working on a Wedico Loader that needs a new pump motor and I am wondering what my options are?
Has anyone put a brushless motor on one?
If I get another brushed motor is there an aftermarket one that is better than the one from leimbach?
Old 01-22-2012, 08:28 PM
Default Re: Leimbach pump motor options?
I believe the motor Leimbach is using now is Johnson.
At one time many europeans were replacing this motor with one from Faulhaber, which had a much greater efficiency & drew less amperage. I don't recall the part#, but I do remember it being a couple hundred $ item.
What's wrong with current motor? Is the pump seeping oil into it?
Old 01-22-2012, 09:01 PM
The motor was saturated when Jimmy bought it used and then at the show it was accidentally saturated with oil again and fried this time.
I don't believe there is a leak or problem with the pump or the lines just oil mistakenly spilled onto it first during shipping and then second from filling it. Because I pulled the fried motor out and it was nice and dry inside where the coupler is which I was happy to see.
I would think that someone would have found a nice aftermarket brushless motor system that would work nice but, I couldn't really find anything via google.
Old 01-22-2012, 09:15 PM
Odd as it sounds, I saw at least one guy running a stock Tamiya silver can on his Stahl bucket dozer's pump. Same thing happened to his motor. Oil got inside it, and shorted it out. If it works good, and it looked like it did, from the videos he posted, it'd be a nice, cheap option. Sorry I really can't offer any help on finding a brushless motor. I always thought most brushless motors, driving pumps, had remote mounted motor plates and ran a belt drive to the pump, via sprockets?
Old 01-22-2012, 09:22 PM
I actually have a stock tamiya (metal back end) in the loader now but, I had to power it with an esc because the full 12 volts from the battery was way too fast.
Old 01-29-2012, 05:26 PM
ahhhhhhhhh gentlemen oil will not short out anything electric as it will not conduct electricity
if your motor shorted out it was something else but if your oil is full of metal shavings then it will short your motor out
may have soaked the brushes
we use oil in most big transformers to cool and protect the busses inside
and to stop any arcing inside
and water will not conduct electricity either , it is the impurity,s in the water that conducts electricity
Old 01-22-2012, 09:26 PM
Hmm, I wonder then, if that guy ran the pump on 7.2 volts? Stock silver cans are 27 turn motors, so maybe a 45 or 55 turn would be perfect?
Old 01-23-2012, 03:38 AM
Michael S Michael S is offline
Michael S is on a distinguished road
I have been runnig a LRP Trukpuller 2 7,2 volt at 12 v in a stahl excavator
Old 01-23-2012, 08:01 AM
He might have just lowered the voltage with an esc?
Great info, I was thinking about trying an 80T crawler motor. I guess I'll order one and try it. Are you powering your motor direct with 12 volts or are you using an esc?
Old 01-23-2012, 12:24 PM
it ran with an esc but on maksimum, but now i have a JUNG pump and i have mixed my radio so the motor only runs when i use a function on my excavator
Old 01-23-2012, 03:59 PM
don't waste ur money on 80t. A 80t on 12v will not work, I have tried it. Only close motor I have used is lrp truck motor on 12v.
Old 01-23-2012, 06:45 PM
Thanks for the info. I'll give the rc4wd 80T motor a shot and see how much current it draws at 170 psi.
I looked up the specs and the LRP Truckpuller 2 is an 80T motor so, I went ahead and ordered the rc4wd 80T motor to try. I figured for $15 shipped it was worth a shot.
Old 01-23-2012, 08:03 PM
Blender's Avatar
Blender Blender is offline
i ran a holmes hobbies crawlmaster sport outrunner on my leimbach pump. it was completely bolt on. It was a little fast with a 950kv rating, but that's easy to dial down with a simple airplane speed controller.
I've since swapped to a tiny outrunner it's only half an inch long and spins a little slower than the crawlmaster. So far no problems, but the machine hasn't seen much use. I'll snap a picture when i can. It's comically small.
Old 01-24-2012, 06:58 PM
trucker n's Avatar
do you have a link to that motor and does it bolt up same as stock motor
Old 01-24-2012, 07:39 PM
Blender's Avatar
This one will bolt up without any mods, although it will spin a little faster that the one i used before.
I can't remember the specs on this little guy, but it needed a custom adapter plate and i had to cut another motor coupler to accept the 2 mm shaft.
Old 01-28-2012, 12:01 PM
Well, the rc4wd 80T motor works nice. It only pulls .5 amps at 8.3 volts and 190 psi.
I ran for an hour and 15 minutes on one charge so, that is pretty good. That was running it almost non-stop though so, maybe 1 1/2 hours or more if resting between loading trucks.
The motor sits at about 90 degrees and the esc sits at about 96 degrees.:-)
Video of current draw with the pump running constantly:
http://www.youtube.com/watch?v=BaeCC...1&feature=plcp
Video with DX7s and mixing on the hydraulic functions:
http://www.youtube.com/watch?list=UU...ture=endscreen
Old 01-28-2012, 04:51 PM
fantastic result.. and the bucket and boom move a lot quicker now.
Elliot.
Old 01-28-2012, 06:11 PM
Thanks, here is a video with sound on and off so that you can hear when the pump is running.
http://www.youtube.com/watch?v=ZoK_a...vX_EuC2dhah0mM
Old 01-28-2012, 07:10 PM
Great video. Seems like you found a winner there. Amp draw seems very reasonable!
Old 01-28-2012, 09:44 PM
Well done Scott.
My 922 is the only one I ever put a guage on & I set the press to 15bar (210psi).
The older two hoes, the press could have been higher, I had an amp meter wired in thru the plug... cyls moving - 1.1, no movement - 2.1amp.
Your due dillengence has paid off & benifited all of us. Thank you.
