Old 02-02-2012, 11:44 AM
sgt hopkins's Avatar
sgt hopkins sgt hopkins is offline
sgt hopkins is on a distinguished road
Default tapping my frame
Ok, I have my frame rails with a buncha holes, whats the best way to tap them? what size tap? or should I just get a screw and thread it in?
Anybody who runs is a VC, anybody who stands still.. is a well diciplined VC!! GET SOME!
Old 02-02-2012, 12:06 PM
Gregg Gregg is offline
Gregg is on a distinguished road
Default Re: tapping my frame
What size screws will you be using? The normal screw size is an M3x.05. That is the best overall size to use. The tap you would need is for that screw and it takes a 1/8th clearancing bit . What size are the holes in the rails? You will need to tap them according to the hole sizes you currently have. You will destroy the screws and rails if you just try to ram home screws in the current holes.
Old 02-02-2012, 09:26 PM
rc_farmer's Avatar
Master Builder
1/8 is gonna be too big for a 3mm tap. Need to use 3/32 with some tapping fluid for the alumunium. Stops it from gumming the bits up.
Giving up is not an option!!!
Old 02-02-2012, 11:03 PM
I use #43 .0890 . the tap specifies 2.5 mm .0984 . I use #43 with no probs also it's the same for my 4-40 sae treads . Get a spiral point (gun tap) for non blind holes , works so much better , just a little more $ then your std taper/plug tap . when tapping use some cutting fluid of some sort and keep the tap clean
Old 02-02-2012, 10:51 PM
Well I just ran about twenty M3x.05 screws in 1/8 holes with plenty of meat left.
That is the bit size that was recommended by the hardwhare supplier and they even supplied me with a free drill bit and tap for those screws.
Old 02-02-2012, 11:24 PM
thats funny cause , 3 mm is .1181" and 1/8" is .125 not much meat left for threading . I use .125 (1/8) for my through holes for 3 mm .
Old 02-02-2012, 11:37 PM
AAHHHH!! Too many numbers and fractions and .....
I didnt drill the holes myself, it was done for me, I am pretty sure it is all the same size holes as the stock KH. Ima just find a tap that fits just snug enough to tap em and go from there. If I screw one up, I can just nut the back of it and keep learning..
Old 02-09-2012, 08:08 PM
roadranger's Avatar
White Line Fever
What drill size to tap for 2mm screws in the top flange of the rails?
WILDCAT T&C
Jim B.
Colorado Springs
Old 02-09-2012, 08:16 PM
Snochaser's Avatar
Hi- jack alert!!
While we're on the subject of tapping..........What size are the screws that are used the the mud flap holders? I need to get a tap and bit for them.
Ben
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 02-09-2012, 08:39 PM
Trucker Al's Avatar
RoadRanger,
you need a 1.6 mm drill for a 2mm tap.
