Old 02-05-2012, 10:27 AM
jimkidmotorsports jimkidmotorsports is offline
jimkidmotorsports is on a distinguished road
Default where to get motors
im building a big dozer it will weigh like close to 70 lbs and need two geared motors for the drives where can i get them thanks in advance jim
Old 02-05-2012, 10:49 AM
Ken Orme Ken Orme is offline
Default Re: where to get motors
Junk yard---windshield wiper motors from a full size auto.
Old 02-05-2012, 10:54 AM
thanks ken are they geared do know
Old 02-05-2012, 12:52 PM
Vanisle Vanisle is offline
I believe RCLogger uses off set gear motors from Servocity for his dozers (check his thread in the construction section). Here is a link to the motor (I think):
http://servocity.com/html/25_rpm_offset_gearmotor.html
Old 02-05-2012, 01:46 PM
thanks his are too small though for mine but will look on the website thanks
Old 02-05-2012, 02:26 PM
Some of them have a worm gear on the shaft. That is about all I rember as it has been a very long time since I have had one of them appart.
Also check "surplus center" sometimes they also have small air and hydraulic cyliners for a few dollars.
They are located in Lincoln Neb
Old 02-05-2012, 03:05 PM
You can look at robot marketplace too. http://www.robotcombat.com/products/motors_main.html
Old 02-05-2012, 04:50 PM
tman1986 tman1986 is offline
tman1986 is on a distinguished road
Hey, ive been looking for motors lately too and i've had plenty of success on ebay
my searches are simply the following
gear motor
geared motor
gearhead motor
and i find tons of items like this one
ebay item # 360431287876
specs are 21-rpm @ 12VDC, 4 ft/lbs torque on that one (thats almost 800 in,oz)
and goes up to 7 ft/lbs @ 41 rpm on 24vdc
i dont know thats where i would start if i where you, theres hundreds all shapes and sizes
Trevor
Old 02-06-2012, 12:49 AM
Hey Trevor, if I remember correctly, Greg's D8 weigh's around 28 lbs? So if you double the torque of his motor's, then you should have a baseline starting point for motor choice's. Cheer's, Neil.
Old 02-06-2012, 01:24 AM
I wasn't suggesting he use those motors, i said there are plenty like that, obviously he would have to find one's that meets his specific needs
also i do not know who greg is or anything about his D8 (guess i haven't read everything here yet) i was simply making a suggestion
sorry about the misunderstanding
Trevor
Old 02-06-2012, 10:34 AM
hay thanks guys i found a couple wiper motors for cars i think will work fine will let you know cause i can get more of these and they are brand new and cheap
Old 02-06-2012, 02:05 PM
Hey Trevor, Greg's build thread, http://rctruckandconstruction.com/sh...light=RCLogger
Just trying to help!
Old 02-06-2012, 06:04 PM
have you look at some of the new 11.1 volt drills ,you could check your local pawn shops and find them cheap or yard sales , plenty strong and even a clutch you can adjust to not break tracks lol
