Old 02-26-2012, 11:21 PM
headers headers is offline
Default wiring servonaut
does anyone know how to wire and setup the servonaut system smt,ml4,s20 and the bma with the jumpers?
ricky
Old 02-28-2012, 04:13 AM
gungunhl's Avatar
gungunhl gungunhl is offline
gungunhl is on a distinguished road
Default Re: wiring servonaut
Hi ricky,
look at this link - its only in german but it will help ( maybe using some translation software )
http://www.servonaut.de/shop/media/p...1299244735.pdf
Regards from Luebeck/Germany
Günther
Günther
from Lübeck, Germany
Old 02-28-2012, 07:25 AM
Brel's Avatar
Brel Brel is offline
A English version of Günther's wiring diagram
http://www.servonaut.de/shop/media/p...1295631318.pdf
I use just the BMA pump module in my tracked loader with a dual ESC and Hook lift skip truck with a Tamiya MFC- 01
to get the pump to run for a set time after the hydraulics have stopped
you put the jumper on pins CD turn on the power and the after the time you want the pump to run for, put the jumper on pins AB, you do not need to have the TX turned on at this stage and when you start the model turn on the TX first and then the model and this sets up the BMA controller, otherwise it sets to the default time
I have got the run time after the sticks have been released to about 1.25 seconds
Old 02-28-2012, 07:35 AM
Thanks guys i will check them out
Old 02-28-2012, 07:08 PM
awesome document and qquestion - I have been very cautious about buying servonaut but this really helps.
Crhis
