Old 03-17-2012, 01:18 AM
Mitch Mitch is offline
Mitch is on a distinguished road
Default ServoNaut BMA
Does anyone know how to program the ServoNaut BMA Hydraulic Module, so as to reduce the pump run time?
Mitch
Old 03-17-2012, 03:40 AM
gungunhl's Avatar
gungunhl gungunhl is offline
gungunhl is on a distinguished road
Default Re: ServoNaut BMA
Hi Mitch,
I found some information at servonaut webside. Unfortunaly its in german:
Einstellen der Pumpenlaufzeit
Die Nachlaufzeit der Hydraulikpumpe ist ebenfalls einstellbar:
1. Steckbrücke auf CD einsetzen. Schalten Sie erst den Sender, dann
das Modell ein. Die Pumpe läuft an.
2. Nach Ablauf der gewünschten Pumpen-Nachlaufzeit die Steckbrücke
abziehen. Setzen Sie die Steckbrücke wieder zurück auf die Position
AB oder BC. Die Pumpe schaltet ab. Nach ca. 2 Sekunden kann das
Modell abgeschaltet werden, die Programmierung ist beendet. Die
Programmierung kann beliebig oft wiederholt werden.
I tried a translation with a computer program
Adjusting of the pump term
The postterm of the hydraulic pump is also adjustable:
1. Jumper on CD start. Switch only the transmitter, then
the model one. The pump starts.
2. At the end of the desired pumps-postterm the Jumper
depart. Put(Place) the Jumper again back on the position
FROM or BC. The pump switches off. After approx. 2 seconds this is able
Model are switched(turned) off, the programming is finished.
Programming can be often repeated arbitrarily.
Maybe its understandable and will help.
I post the german description as well - maybe you can check again.
Regards from Lübeck / Germany
Günther
Günther
from Lübeck, Germany
Old 03-17-2012, 04:24 AM
apfubar apfubar is offline
I am running one in the 966 loader...
It plugs in between each of the servos and the receiver... And a line to the pump motor
If any of the servos are off dead centre, the BMA turns on the pump. When they are at dead centre for the required time the pump shuts off.
Cheers,
AP
Old 03-17-2012, 12:30 PM
Your instructions were very helpful. Thank You !
Mitch
