Old 09-06-2010, 07:41 AM
kolpen kolpen is offline
kolpen is on a distinguished road
Default Kverneland RB 100 - 1/16
Headstock
Turning part. Also take a look at the small tools. It’s actually real tools made for the small nuts.
In these two following pictures you will see the secrets of the turning part.
Two 90dgr. bewelgears and a motor do the trick. A potentiometer is mounted to set the endpoints and it can be fine tuned via the radio controller.
Here is the start of the first furrow adjustment. It will be adjusted via a spindle…
Rearend is done, except of the fender over the cylinder. Turning cylinders are done with adjustment-nuts
When you take a look under the plowframe you will notice the wire coming out to raise and lower the plow. Fine tuning is done by the nut on the cylinder
Old 09-06-2010, 07:44 AM
Default Re: Kverneland RB 100 - 1/16
All functions are working; (Video at bottom)
Landwheel steeres left and right, stopsrews are securing that the wheel is aligned with the coming landsides.
Plough raises and lowers, again the stopscrew secures the correct depth.
Boom turns over and tiltscrews are in place to secure that the boom lays horizontal when the tractor drives in the furrow.
First furrow adjustment is working. Furrowwidth adj. is coming soon….
Electronics consists of a printboard from a Hitec HS 5045 digital servo. But the potentiometers has got a 2 kOhm resistance to achieve a full 180+ degr. operation. Instead of the 120degr. standard. Endpoint and trims is made from the transmitter.
Video says more than words and pics….
Here is a link : http://www.youtube.com/watch?v=JmtqK4cimQY
Old 09-19-2010, 04:26 PM
Finster's Avatar
Finster Finster is offline
Really amazing machining and brass work! Even making the miniature tools to go with it, just blows my mind. What diameter is that motor you are using and where do you find such small motors with gear boxes like that? Thanks.
Old 10-05-2010, 08:53 PM
rc_farmer's Avatar
Master Builder
Anders, are you running the Falhauber motor in this tractor......if so, which ESC are you using.
Giving up is not an option!!!
Old 10-13-2010, 05:23 PM
jffhrvstr jffhrvstr is offline
jffhrvstr is on a distinguished road
That is amazing detail and craftsmanship! Can't wait to see more pics of it
Old 10-25-2010, 12:31 AM
OhioFarmboy's Avatar
OhioFarmboy OhioFarmboy is offline
OhioFarmboy is on a distinguished road
Simply amazing is all i can say,those little wrenches really add to the realism.Just watched the video also and can't wait to see the plow bottoms attached.Great job!!!!.Randy.
Old 07-02-2013, 05:13 PM
Hello everybody
Time flies and I have a made a little progress on my 7 furrow reversible plow.
As you can see I am alomost there. I mounted all the beam supports to make it variable between 19 and 31mm or 30-50cm or 12-20" in real life -and it works
Its manually adjustable via a spindle just like the first-furrow adjustment.
Then I made a new wheel with hub and a tire-thread pattern almost identical to real one. At least the dimensions is correct.
Then I've got all 'the same parts' cut out for me. I actually wanted this project to be 'hand made' but I thought that the project took me from somewhere around 2009 till now, and it would only take longer to do it by hand...
So I guess I have been around many aspects of designing and building in this project. By hand and by CNC, from drawings on a paper to exact measurements on the screen.
Mouldboard is from stainless steel and all the 'parts' has been laser-engraved to give a realistic view.
OK, so here is some pictures for you all:
Old 07-02-2013, 11:21 PM
Wow incredible job on the plough
Old 07-03-2013, 06:16 AM
D8R D8R is offline
Very nice model and good skills on making all those small details. Have never thought about using servo parts to control an electric motor. Guess you can use cheapest servo as long as not going over rate of current.
Dan
Old 07-04-2013, 01:16 AM
This is the most detailed farm equipment build I've ever seen! I know there are guys who build models with a lot of detail for static display, but this is all functional! Amazing! Keep it up!
Old 07-05-2013, 04:23 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
Glad you are still finding time for hobbies Anders. I think your work is fantastic and the cut parts certainly made the replication easier than by hand. Excellent project and detailing!
Old 07-07-2013, 04:41 AM
Master of precision and details...
regards,
Frank
Old 10-09-2013, 10:36 AM
Finally
The plow is now ready for the first take off. First test will take place in Husum, Germany, at Traktorado. I am excited and curious to see how it will work in the soil.
First off, I know that the design has become very fragile due to some of the details and need to hide away all electronics etc.
So, let's see if this will become a shelf model or a real RC model....
Here is some pictures. Still need some details like oil tubes and so on....
I think I could make better pictures, without all the annoying shadows. They will come after Husum.
Thank you all for following
Anders Kolpen
Old 10-09-2013, 10:54 AM
Stuart's Avatar
Stuart Stuart is offline
Wow that is a thing of beauty
Are you going to plough out of the furrow with your tracked JD?
Would look good behind my JD 9530
Stu
Old 10-09-2013, 11:53 AM
Hi Stuart
It will be pulled with my JD 7920, in furrow.
I'm afraid that your wide tires may give some issues on this one....
Very nice model you are building! Looking forward to the articulated area!
/Anders
Old 10-09-2013, 02:17 PM
Stuart's Avatar
Originally Posted by kolpen View Post
Hi Stuart
/Anders
Hi Anders, I think I could make it work with the fat tyres
Thankyou, I'm not, thats going to be the tricky bit
Stu
Old 10-22-2013, 04:33 PM
Too good for the dirt...
regards,
Frank
Old 10-09-2013, 12:11 PM
Mojave450rider Mojave450rider is offline
Mojave450rider is on a distinguished road
Simply amazing job! What an incredible attention to detail and function, superb job.
Old 10-28-2013, 02:40 PM
Video from Traktorado in Husum, Germany.
Thanks to Frank 'Grainfarmer' Rohner for the raw footage.
http://www.youtube.com/watch?v=CcD4g6R62_Y
Thanks for watching!
Old 10-29-2013, 03:59 PM
No problem...you´re welcome.
Fantastic model! Works pretty good...
regards,
Frank
