Old 04-08-2012, 03:33 PM
trucklover trucklover is offline
trucklover is on a distinguished road
Default PMD tranny in globeliner
I am having problems with the pmd tranny because my motor is spinning,the first driveshaft is spinning,but the rear driveshaft from the pmd unit back to the wheels is not moving. If I move the wheels with my hand, the rear drive shaft will move. Is there something going on within the unit?
Old 04-08-2012, 03:54 PM
Default Re: PMD tranny in globeliner
I am guessing u have a 4:1 reduction transmission? If so try flipping it around u might have it installed backwards. If no fix let me know.
Old 04-08-2012, 04:02 PM
Will try to see what will happen when i turn it around. Thanks.
Old 04-10-2012, 02:40 PM
Turns out that one of my grub screws were not tightened enough. It works fine now but I am not happy with how the pmd 4:1 is working along with the stock 3 speed. It takes several tries to get it to go into reverse, and the stock tranny makes noise before it engages a gear. It never did that before.
Old 04-10-2012, 03:13 PM
You have an issue with the 3 speed and from what your describing it is with the shift servo and your end point settings. The GRU will have no effect on the trans all it will do is slow the truck down.
