Old 04-10-2012, 03:00 PM
trucklover trucklover is offline
trucklover is on a distinguished road
Red face Is it the tranny,the gru, or me?
What kind of driving characteristics should I expect when driving a pmd 4:1 gru along with the stock 3 speed? The 3 speed ran fine until I installed the gru. I have one of those truck puller motors from gardentrucking and this thing seems as though it does not want to drive slow and steady. It makes my tranny make noise and then it gives me no movement, then speeds up quickly. I have a notched left stick throttle set up. Do I have to change my driving technique?
Old 04-10-2012, 03:19 PM
Default Re: Is it the tranny,the gru, or me?
It can be a little jerky due to all of the backlash in both the trans and GRU as well as the drive shafts. Before you added the GRU it had a tall enough gear that it absorbed the backlash but now that you have shortened the gear the backlash in the gears will be more noticeable.
Basically you will have to be easy on and off the throttle and that can be hard without a spring loaded stick for the throttle.
Old 04-10-2012, 04:55 PM
MACK Daddy's Avatar
Also Check to see if you installed the PMD GRU correctly...the side that spins quicker is the one that gets hooked to the tranny
just a thought
Alfy
Old 04-10-2012, 05:09 PM
thanks will check. Glenn
