Non Rc Model Trucks and Equipment This area is for the custom builders of the "MODEL" world to show there NON RC metal and plastic creations and builds. |
I guess this fits here its a non r/c and its a truck
![]() Started this build about a year ago and it'll prob take me another one to fully finish it. I Started off with the remake of the White Freighliner kit and the duel tandom pup trailer kit. There are several mods going into to as well as lots of lights ( the main set back of build time on it) i think the last count it'll have just over 400 leds..... ![]() ![]() Cab together and test fit ![]() Frame painted and detailed ![]() Motor assembled and started to be detailed and weatherd ![]() I like details ![]() tires and 5th wheel on ![]() my start at the madness.... ![]() ![]() they are Model railroad 1mm leds... ![]() So needing a break from the cab and wiring i decided to start the tailers and dolly.. well i couldnt leave that alone either so i started wireing that up too ![]() ![]() ![]() I used Cat-5 (phone wire) for my wires, and the smallest solder i could find.. These things pop easily soldering... Got the trailers mostly built ![]() Started my new bumper ![]() I hop around on builds idk why maybe i have ADD but i always do when building i always have 2 or 3 things being built at once. Motor and radiator in and mounted ![]() Started the interior.... painting with a toothpick for these small squares ![]() Then i came up with some ideas.. The original idea was to house the battery in the cab and then have the cab power the trailer, the trailer the dolly and the dolly the trailer.... and it still may happen just trying to figure voltage and led count forward resistance AHHHH ![]() ![]() ![]() then drilled small holes and put a metal piece behind the hole, so when you plug in the cables it conects the power!! the back of both trailers will get sockets for the dolly to hook up to so either trailer can be the lead trailer. Being me and thinking overkill now that i got into the bigger trucks with my globe and the MFU i may have to pick up a light&sound kit to wire this all right and make it where i can remotely turn lights on/off have turn signals or flashers etc.... kinda the expensive route but hey i already have $200 in leds right?!? Heres what im talking about ![]() ![]() Thats the progress so far. My workshop isnt heated so in winter i dont build much... But i should be resuming soon enough and will be adding updates.. what do you think so far? |
Looking real good so far. I love the idea of led's in a static model, it add's realism and that is cool. Can't wait to see her finished. I have a freightliner like yours, I had trouble with the steps, so take your time and be patient.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
Looks good man! For wiring.... I don't know what battery you plan on using or what your LED's are rated at but when wiring my truck with a 7.2 volt supply and 3V LED's i could only run 3 LED's in series and wiring in parallel can be a pain
![]() J.D. |
Yea they are 3v 1mm leds.. Problem is when I ordered 200 more of different kind they came in 3 different voltages. That's my main hang up is the lights. The truck can be done in 2 days easy but until I figure out wiring I'm stuck where I'm at and pulling my hair out. Was thinking of going the add on relay board from as-tronics as thru say it can handle 200 3v leds... So idk. I need help figuring it out or I have to do it with fiber optics and that's easier said then done as well. I'm about ready to scratch the light idea just to finish the truck
COOL! looking great! love the old school look. that old frieghtshaker is going to light up the night with that many lights on.lol.
Shaun legaarden |
Nice Aaron
