Old 04-15-2012, 09:09 PM
cyanide cyanide is offline
cyanide is on a distinguished road
Default Sheet Metal Tools & Roller Question.
Hi,
I mainly do sheetmetal work, building bodies and the like for RC cars. I do not have a workshop, but I am lucky to have a friend that lets me hang out at his pretty much every weekend and also store my tools there.
My favorite sheetmetal tool so far is my Swaging Jenny (bead roller).
I have recently got a 760mm x 1.0mm 3-in-1 Metal Shear Press Roll
We understand the basics of the Shear and Press, but we are not so sure about the correct usage of the Roller. Are there any beginner tips out there for using a roller to get nice smooth even curves in the sheet?
Thanks.
Old 04-16-2012, 04:10 AM
Default Re: Sheet Metal Tools & Roller Question.
Slip rolls are not that difficult to use. Start by making sure the third roll is parallel with the pinch rolls. Pinch a sheet between the pinch rolls making sure they have equal pressure and snug it enough to get enough traction to feed the metal through. Try rolling a piece back and forth raising the third roller after each pass. Check your radius with a template or remove the work and hold it on your full size drawing or what have you. Make sure you count the same number revolutions on the adjusting screws to keep the rolls parallel or you will start forming a cone. With this style of small rolls, you won't have trouble changing your mistakes because they can't bend very thick sheet in the first place. The grooves are to keep from flattening a bead that was formed for stove pipe. You could also use the grooves to form coils from round stock. You could even modify them to roll small channels and angles but the angles would need some sort of leg in roll to counteract the camber on an angle.
Mostly bending is a black art and experience is the best teacher. I've been rolling metal for 30yrs now and there are some rules to follow, but not every piece of metal comes out the same.
Old 04-16-2012, 12:53 PM
Thank you for the advise 9W Monighan.
Next time I am over at the workshop I'll put a few test peices through the rollers.
