Old 05-06-2012, 09:24 AM
mack kid mack kid is offline
Default PACIFIC P12W3
This is my first scratch built truck. It took me one year to get this far so more will come slow and steady. Most Pacific trucks were custom built, the idea is to take from that and add options to my liking. This will be heavy haul winch truck. some inspiration.
Waiting for Parts!
Old 05-06-2012, 09:31 AM
Default Re: PACIFIC P12W3
Here is some of what is done to date.
Waiting for Parts!
Old 05-06-2012, 09:45 AM
Nice start! I wondered what you were building that was so heavy! What are the rear diffs from?
Reg
Old 05-06-2012, 09:54 AM
They are from RC4WD Black well axle. Rig is 20 lbs as of post.
http://store.rc4wd.com/Blackwell-X1-...ack_p_450.html
Waiting for Parts!
Old 05-06-2012, 10:14 AM
It has 3 frame rails bent as c channel from 22 gauge galvinized stock. inside rails are one inside the other with 3rd rail outside. 1 inch tall by 1/4 inch wide.
Drive is Tamiya standard 3 speed then a split shaft pto 1:1 then an RC4WD R2 two speed. i like the speeds and torque is plenty. i have sheared two drive pins on test pushes so far. and had to switch from plastic to metel gears in the 1:1 motor combiner.
Rear and front suspension are scratch built front leafs are from Tamiya F 350 rear leafs are scratch built.
Waiting for Parts!
Old 05-06-2012, 10:32 AM
Thanks, I want to build an 850 Kenworth but it will be 1/10 scale to match my other stuff so I may have to make my own diffs. It would be nice if I could find something large enough that worked though instead.
Keep the pictures coming!
Old 05-06-2012, 10:34 AM
plow jockey's Avatar
That truck is a beast.Great job on the suspension and wheels.Truck is looking 1:1,cant wait for the updates.
Old 05-06-2012, 10:53 AM
Short vid's from first test drive.
Cant forget the Brains behind the operation
Waiting for Parts!
Old 05-06-2012, 11:59 AM
Your off to a very good start! It' really a big truck.
Old 05-06-2012, 12:22 PM
I plan on moving rear bogies forword after i add two tanks fuel and water, the overhead and the winch once i do that i can figure out were rears will end up
I just cant make up my mind on long or short wheel base. Let me know some opinions. Thanks Don
Waiting for Parts!
Old 05-06-2012, 01:03 PM
diddys trucking's Avatar
diddys trucking diddys trucking is offline
diddys trucking is on a distinguished road
Hi i think if you made it a bit longer you could have a sleeper to plus it would look cooler
super biuld so far i think i will be looking out for your updates.
Dave
Old 05-06-2012, 02:20 PM
WOW that truck is cool!! Ive been wondering what you have been working on! Very cool build
Old 05-06-2012, 10:03 PM
elephants14 elephants14 is offline
elephants14 is on a distinguished road
Just a question. Is there any movement in the front suspension. It looks like there is not shackle, so it can never give. Or am I wrong. Definetly interesting build. Like the look of these trucks.
Cody
Old 05-06-2012, 10:29 PM
Great start! I like the "non street legal" giant's. This one is being watched There's a bunch of neat Pacific video's on youtube.
Old 05-07-2012, 01:05 AM
cyanide cyanide is offline
cyanide is on a distinguished road
Cool truck, it looks like it will be a monster.
How are you finding the Blackwells? I have always wanted to get some, they look so **** nice, but the $$$ is pretty steep for me, are they worth the coin? Are they rock solid?
Old 05-07-2012, 08:06 AM
Cody
Yes there is movement and only one anchor. the front top 2 leafs of spring bundle are straight and sliding on a derlin block. rear of top spring is looped and bolted.
Waiting for Parts!
Old 05-07-2012, 08:20 AM
THANKS for all feed back
Blackwells are ok. they are nicly built. BUT drive center is off center this caused problems with driveshafts between rear axles and only because i wanted the wide supports like the 1:1 if you have a support like IHB did on his mack there would be no problem. also i have sheared both pins in the front steering axle just pushing a chair around the house. they have an upgrade for 40$ now i see why. i ended up putting roll pins in so far so good.
keep in mind they are locked diff's
the 1:1 pic's
the pic on the right is how the pumkin should be. off center.
but yes very well built
Waiting for Parts!
Old 05-11-2012, 05:53 PM
Started on cabin deck and fender supports
This is main frame. deck and fenders mount to this.
Here is a pic of building rear suspensions i have some older build pics i will post as soon as i have time.
Waiting for Parts!
Old 05-11-2012, 06:05 PM
great looking build amazing work!!
Old 05-14-2012, 07:25 PM
Those are some rather huge trucks - had no idea? And your truck is coming along nicely....
Izzy
