Old 05-16-2012, 04:41 AM
apfubar apfubar is offline
Default New Toy
Well, I have been a very naughty boy...
As you may be aware I have been looking into an Excavator...
So on the 14/04 an "opportunity" arose, to purchase one... a little bit of waiting (in comparison to other options) later and this arrived on my door step at 5pm today:
More to follow.
AP.
P.S. Thankfully Sydney never gets below 0, so it's not too cold in the dog house!
Old 05-16-2012, 04:44 AM
Default Re: New Toy
After opening the top, this is the view:
Then a little bit of work later:
And now:
Hopefully the above works, both in terms of the image and the Excavator!
Cheers,
AP
Old 05-16-2012, 05:37 AM
Default Re: New Toy
Congratulations Andrew... glad to see it arrived safely and quickly.. get the batteries charged and lets see some videos!
Elliot.
Old 05-16-2012, 05:42 AM
titandigs's Avatar
Aussie Fabricator
Default Re: New Toy
Looks great, new toys always give a good feeling. Hope we see some photos of it dirty soon. I am waiting for my new toys also Scale Art 8x8 half pipe tipper and the Leibherr 576 2+2. I think I may have to move the dogs over.
Old 05-16-2012, 05:48 AM
Default Re: New Toy
Congrat's on the new hoe! I like the 2 piece boom, not common in my neighborhood.
Old 05-16-2012, 06:07 AM
Default Re: New Toy
The 2 piece boom isn't common over here either...
Just got to work out how to set it up... and confirm that nothing is missing. Another minor detail, I have a 9 channel radio, needs 12 for everything. I guess the 2 optional channels won't be used for a while, so then it is down to 10.
Need to think about it a little while.
The receiver is bound, just need to setup the channels correctly... and learn how to drive it.
Cheers,
AP
Old 05-16-2012, 09:07 AM
kaptain Jack's Avatar
Default Re: New Toy
Hey, what make is it?
Old 05-16-2012, 01:13 PM
Snochaser's Avatar
Default Re: New Toy
Awesome! Jealous!
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 05-16-2012, 03:17 PM
Default Re: New Toy
It looks like a very nice machine. Which make is it?
Old 05-16-2012, 03:28 PM
Default Re: New Toy
I'm jealous! I want one too. Let's see a vid of it. Looks Sweet!
Old 05-16-2012, 04:13 PM
Default Re: New Toy
That must be an Liebherr Modelle hoe, right?
Awesome machine you got there, can wait to see a video of it!
Old 05-16-2012, 05:07 PM
Default Re: New Toy
Yep that is correct... supplied by Liebherr Modelle (now Premacon).
Last night(it is now 6am) I had the hoe powered up for the first time.
I have tested the:
- swing motor
- L&R tracks
- pump
- main hydraulic functions.
On the todo list:
- configure the radio properly
- choose the stick setup I want - probably
- Left stick - bucket crowd + boom in/out
- Right stick - swing + boom up/down
- work out how to control the adjustable arm - I think I will utilise a switch - to flick between controlling the boom in/out and the adjustable section (If I can work out how to make the radio do it)
- plug the controls into the correct locations (this sounds easy, but I didn't get it right last night).
- set the center and end points
- setup the pump control mix
- create a new breather/find the missing breather (probably lost in customs)
Hopefully I can get some of that done today, assuming I don't have too many chores assigned to me by the missus!
Cheers,
AP
Old 05-17-2012, 06:02 AM
Default Re: New Toy
Some photos of the 1:1 machine
Elliot.
Old 05-17-2012, 07:17 AM
Default Re: New Toy
Elliot,
Those photos are great, interesting to see what made it into the model.
All,
Here are some other shots:
- In transport mode...
- Testing the reach...
I have now sorted the base radio setup, including:
- switch mode for the adjustable arm
- switch for the lights
Upon closer inspection it does have the quick release, it is manual, I wasn't sure if it would come with it(bonus)... eventually I will make an electric/hydraulic version.
Also found out that the breather is missing... my father has a lathe in QLD, he will make one and send it down, as it is just a cap screw bolt with a hole in it...
I may not get a video up until next weekend, as I am away this weekend.
A couple more photos may be up tomorrow morning though.
Also does anyone know if Premacon uses the same oil as Wedico? I just have some Wedico oil here, but I didn't get any for the excavator...
Cheers,
AP.
Old 05-17-2012, 08:23 AM
Default Re: New Toy
Hi Andrew,
Looking at your pictures it looks like most of the detail is transferred to the model. It also fits onto the Carson trailer nicely.
Ref the breather, mine came with a M5 bolt with a hole 2mm through the middle, there is no other breather included, unless you were told there was one? Just above this is a 1/4 turn cap molded into the bodywork, removing that gives you access to the bolt with hole in the middle and keeps the dust and dirt out.
The mechanical quick release is easy to operate, although I'll be watching how you automate it... please make two :-)
Ref the oil, HLP22 is the stuff you need. It's fairly common in Germany, but not so much on the UK, but I managed to find a supplier. No idea in Australia? If you're really stuck, I'll post some to you.
keep the updates and pictures coming!
What radio are you using?
Elliot.
Old 05-17-2012, 04:36 PM
Default Re: New Toy
Elliot,
On the breather it is mentioned in the German instructions I received with the excavator...
See here: https://picasaweb.google.com/lh/phot...eat=directlink
and here:
I did receive an English tranlsation via e-mail which states in part:
5th Transport lock
Thus, the model may lose no oil during transport, was an M5 screw Phillips in the filler neck of the tank is screwed. Replace them before using with the supplied allen screw M5 with a central hole from. The central Hole serves as an operational model for the tank vent.
On the bottom right of the 2nd page there is a picture of the cap head bolt.
Did you see the Quick release that one of the German guys had modified? With two coils pulling the pins out of the road? That is what I was thinking of... Just have to find the link... again...
Cheers,
Andrew P.
Old 05-17-2012, 04:47 PM
Default Re: New Toy
Hi Andrew,
Yep that is the same document I got...
Mine was shipped with the phillips or crosshead screw in place, in a seperate bag in the box there was a allen cap head bolt with a small hole in the middle, like in the picture you sent, I removed the phiilips screw and installed that one...Is that the one you are missing?
If you can find the link I'd be interested in having a read.
Elliot.
Old 05-17-2012, 05:43 PM
Default Re: New Toy
Yep that is the one I am missing, no separate bag... Likely 'lost' during the customs inspection... It's not in the box(which is now in bits in the shed).
Cheers,
AP
Old 05-17-2012, 09:53 PM
RCLogger's Avatar
RCLogger RCLogger is offline
Default Re: New Toy
Very nice model, you will have hours of enjoyment, congrats..
greg
Old 05-18-2012, 04:58 AM
Default Re: New Toy
All,
Thanks for the thoughts...
A small vid on YouTube... Unloading, a quick dig, then back on the trailer... I need to get some stick time on this beast...
http://www.youtube.com/watch?v=CxdCjnc0MMg&sns=em
Cheers,
AP
