Old 05-19-2012, 04:28 PM
Question battery charging
Hi all,
I finally am starting the build of My tamiya Scania and want to hide the battery in the fuel tank. Is there any way of building a charge input while having the MFU still connected. Thanks
Old 05-20-2012, 07:36 PM
Default Re: battery charging
I havnt tried it but i would think you would be able to as long as you were to put a cutoff switch between the battery and the MFU unit
Old 05-21-2012, 07:07 PM
Have to agree, the cut off switch should be ok. If it's wrong, i'm sure someone could let us know.
Old 05-22-2012, 01:53 AM
Stuart's Avatar
Stuart Stuart is offline
I've fitted a charge socket and mfu cut off switch to my globe, works a treat, can take some pics and post later if you like.
Stu
Old 05-22-2012, 09:08 AM
Stu
i know id like to see thats an issue im trying to fix in mine, i dont want to have to open the truck to get to the battery
Old 05-22-2012, 02:49 PM
Stuart's Avatar
Here you go:
Made up a charge lead:
Piggy backed 2 batteries together for longer run times:
(its not metalic paint, just dust!!!)
Charge lead attached to truck:
Power goes from the batteries through a tamiya plug to the charge socket then + goes to the switch and from there to the mfu via another tamiya plug with the -.
I fitted the tamiya plugs so as it was "plug and play" with future batteries etc.
Hope this makes sense, I can't take any pics of the wiring with out taking the cab off.
Stu
Old 05-22-2012, 05:58 AM
thanks that would be great I've got two scans that i want to move the battery into the tanks... nothing like long grass recking a day
Old 05-22-2012, 03:26 PM
That actually helps out alot!! i like this simple yet effective idea. ill make some holes in my cab floor for the switch and charge port. i like the idea of piggy backing the battery packs, i have 2 one as a back up for when the other goes dead and i still want run time. this deffinitaly gives me ideas as what to do to mine! Thank you!
nice looking globe btw...
Old 05-24-2012, 12:14 AM
1985 kenworth's Avatar
hello i'm new to that idea...you can piggyback the batteries ?do you get power from both at the same time ?does that increase your run time ?can you use any size batteries for this setup currently i use wolfpack 4200 nmh and right now i get about 1 hour run time depending on how heavy the trailer and load is
