Old 06-14-2012, 07:37 PM
Default All you day cabbers
Where and how are you hiding all your gear?
batts esc and all that good stuff
Old 06-14-2012, 08:57 PM
MACK Daddy's Avatar
Default Re: All you day cabbers
It aint easy I will tell ya that....Installing an mfu in a cabover is no easy or great looking task,,Best advise I can give is ....Shelves...lol
Alfy
Old 06-17-2012, 07:51 AM
Shorten wires on equipment once you have a decent layout.
- get the body work done
- lay in the large bulky items first ... aka a speaker if it has an mfu
- lay in the smaller items - making sure you have access to the batteries
(good point here - some trucks the battery is buried - therefore they don't change the battery just kill power to the truck and hook up a charge lead)
Once items are situated - adjust the length of wires cut em back and re-solder the plugs
servo wirees are the worst! the plugs are a pain!
Izzy
Old 06-17-2012, 10:57 AM
i was thinking of a bottom plate for the chassie from
the back of the cab clearing the drive shaft to the fithwheel
then a nice cat walk with the battery hidden there
Old 06-17-2012, 08:09 PM
The battery pack between the rails will work. That's what i'm doing with a plate to "hide" the battery.
