Old 06-23-2012, 10:20 AM
B-Train Hauler's Avatar
B-Train Hauler B-Train Hauler is offline
B-Train Hauler is on a distinguished road
Default Hydraulic hoses
Hi everyone,
Is someone can advise me about what kind of hydraulic hose I can use on a excavator with an hydraulic working pressure of around 800 psi ? The exterior size must be in scale for a 1/12 or 1/10 scale...
Thanks,
Gaetan
Old 06-23-2012, 03:46 PM
Default Re: Hydraulic hoses
Vanisle has hose and fittings check with him. I am running 4mm OD for my bucket and 5 or 6 mm for the main stick and bypass. He is under buy and sell. Ed
Old 06-23-2012, 06:17 PM
The eaton air line that I use is rated for around 300 psi working pressure and 1200 psi bursting stength. I was playing with the pump and boom cylinders on my excavator before I had a relief valve and mistakenly bottomed out the cylinders. Before the pump stopped turning I seen the gauge to just over 40 bar(close to 600psi). The hose was fine but I have a plastic Y fitting in line and it blew it apart! I'm not sure how long it would last at that much pressure but I'm running 30 bar(435psi)+ with no issues.
Reg
Old 06-24-2012, 10:59 AM
Thanks a lot guys!
