Old 09-12-2010, 01:32 AM
Default Hydraulic Pump Motor Control Options
Lots of options for hydra motor control to conserve battery consumption.
Turn pump on/off via remote
http://www.robotmarketplace.com/prod...-BATTLSW1.html
This esc works great for tracked models, but you can also turn off the "mix" feature and run two motors seperately. I use this esc in my articulated dump trk to propel it for/rev and operate the hydra pump. If I were using a better radio I would "mix" the proportional channels of the valves with the hydra pump, but currently I'm using the ratchet stick to control hydra pump rpm manually.
http://www.robotmarketplace.com/prod...ER2X10-RC.html
This is the "auto sense" that Nathan refers to. The slightless bit of movement of the vlaves for oil flow and the hydra pump activates, but you have to have the valves perfectly centered or the pump will never shut off. If I recall correctly, it's about 2 or 3 second delay with no valve movement before the hydra pump turns off.
http://www.leimbach-modellbau.de/start.html
(scroll down left header to LKW Zubehor and click Pumpenbaustein)
Here's a handy translator to read foreign sites.
http://translate.google.com/#de|en|
Old 09-12-2010, 04:58 AM
Default Re: Hydraulic Pump Motor Control Options
Servonaut BMA is very similar to what Leimbach offers.
http://www.tematik.de/servonaut/Prod...r/BMA/bma.html
I have few of those in use. It works nice with Servonaut SMT soundmodule: when the hd-pump starts it will increase the engine revolutions like in the real thing. It will also make the engine sound like it´s under a load when the hd-cylinders move.
Old 09-12-2010, 10:58 AM
Nice find on those ESC's! Robotics is a great source of parts for custom RC's.
Here's a link to the "auto sense"
http://www.leimbach-modellbau.de/Pumpenbaustein.html
Usually in sites like that you can open the link in a new tab and get the URL to paste.
In VA? Check out
Old 09-12-2010, 11:38 AM
I have no experience with Servonaut, but have heard many good things of them, a much more refined electronic product for precise radio control... it's good to meet another who has Hemi1966, should I ever choose to aquire any of their products I won't have to learn any hard lessens while trying to decipher the german instructions.
Great tip, thanx Thor.
Old 09-12-2010, 02:42 PM
Great information Joe. Glad you saw the other thread and posted all this!
Old 09-12-2010, 04:08 PM
dirtpusher9's Avatar
Moderator
How would I wire up an ESC to the pump to shut it off when not in use? I'm more than likely going to need this option when I start pulling this 48 lb, scraper around.
Old 09-12-2010, 05:45 PM
Joe wire it to a 3 way switch Ole told me that. Ed
Old 09-12-2010, 05:49 PM
Joe I got a Servonaut S20 for the loader and it is in English how to hook it up. Ed
Old 09-12-2010, 07:27 PM
Wire the pump motor just the same as you would a drive motor for a track. Though I wouldn't connect the rx lead to a 3 pos switch ch on the radio b/c it would defeat the purpose of using an esc, might as well just use the battle switch relay instead, full on or full off.
On the radio, if you have a proportional dial switch, plug the pump esc into that ch so you can set the pump motor rpm's/rate of hyd flow to where you feel it works well for you. Or if you understand "dual rates" and your radio has that capability, then you can tune your pump to activate when a servo/valve is activated. Read the instructions that came with your radio thoroughly to figure out the dual rates option, it'll explain it much clearer than anyone here can.
Old 09-12-2010, 08:42 PM
Moderator
So I would wire my pump power wires into the battle switch and then plug in the wire from the battle switch into what ever channel on the rx I was going to use to turn the pump on and off with, right? I do have duel rates on my radio, so I would tune it with that, correct? Remember Joe, my extent of electrical is turn the switch on, if that doesn't work I'm lost. lol
Old 09-12-2010, 09:31 PM
tracksntreadslou's Avatar
Heres a vid of how it works...gona have to study my manual to see if i can give it a whirl...gone save an extra channel
http://www.youtube.com/watch?v=cju6hbueaOg
Old 09-12-2010, 10:50 PM
I thought you already had the battle switch Joe, no?
The battle switch is an on/off relay. To wire it in to turn pump on/off, splice into the negative wire between the pump and main switch (cut the wire in half) and place each bared end into the relay terminals. There's three terminals on this relay, you only use two of them. You can either turn on relay to activate/close electrical loop to turn on pump or you can use the other side so when you turn off relay, it closes electrical loop to turn on pump. Instructions come with it and they are very easy to follow. Electronics is not my friend either, but even I can do this much.
If you wish to program your radio so your pump/valves work just like Ole's dozer, then you'll need to wire your electric pump motor to an esc for variable rate/proportional control. You can wire the pump's esc into the same exsisting battery that runs your dozer currently or from a seperate battery. If the esc has BEC capabilities, then just remove the red wire from the rx lead before installing into the receiver b/c your receiver is already getting power from your tracks esc.
You're going to St Louis in a few months, get your items together now to take with you and surely one of the guys there will know how to wire it up... if you really don't want to do it yourself, but it's really quite simple.
Old 09-13-2010, 03:41 PM
Moderator
Yeah, I forgot I had wired it in back when I first built everything and took it out when trying to set the winch up. So all I had to do is hook it back up. I don't ever have to go in there except to charge the bat, so wasn't sure what was in there still. Thanks for the reply, Joe.
Old 09-14-2010, 08:02 PM
Blender's Avatar
Blender Blender is offline
I just played around with a radio mix from the valves to the pump rpm. That's a great way to set it up. I gave the pump a low idle around 10%, then moving the valves increases pump rpm as high as needed. My hydraulics run even cooler now and it sounds really neat.
I'm impressed.
Old 02-08-2011, 09:13 PM
fuzzy fuzzy is offline
fuzzy is on a distinguished road
you gave my oneway esc something to do on my excavator pump thanks for tip
Old 04-21-2011, 07:03 PM
Joe, this is great info can you make it a sticky?
I missed it when I posted my pump question.
Old 04-21-2011, 09:30 PM
aseejr aseejr is offline
Why would you use an ESC as opposed to a switch?
Albert
Old 04-21-2011, 09:45 PM
Albert
I think it might be better for the pump if it is running slowly when it goes to full power than to just turn all all the time from a dead stop.
Old 04-21-2011, 09:54 PM
Full sized equipment recommend full rpm for full pump out put as to not starve the hyd components and also not to over demand the pump. I would think the same hyd principles would apply to our stuff as well and if it is a heat issue you are concerned about a hyd cooler is a cheaper and more effective solution.
Old 04-21-2011, 09:44 PM
I asked the same question Albert. With an excavator or a model with hyd steer cyl's as long as you are using the model you are using the pump. To me it is also redundant to varie the speed of the pump as the spool is a variable control if the speed controller is linear with the servo movement then at a low input with a heavy load in a bucket you would not have the psi for fine control when a higher psi is still needed. On my track loader I use an rc on-off switch to shut the pump off if i want to take a break. Just my thoughts.
