Old 08-03-2012, 05:26 PM
Rhino Rhino is offline
Rhino is on a distinguished road
Default Hydraulic build for John Deer 850J dozer
Hi just thought I'd post a few pics of some hydraulic tinkering which will hopefully end up in a dozer build. Thanks to the many other members who have posted info on hydraulic systems. Tolerances at the moment are a bit hit and miss so I'm only going to make the one cylinder for now and do a bit of testing before I end up with a handfull of leaking cylinders.
File Type: jpg hyd cylinder stripped with size ref.jpg (73.0 KB, 146 views)
Old 08-03-2012, 07:14 PM
Default Re: Hydraulic build for John Deer 850J dozer
Looks like a nice start!
Old 08-05-2012, 02:42 PM
I spent a bit more time on the build today. Resigned myself to the fact that this is going to take some time! A little more than I thought before I started. I'm going to blank the second function off and carry out some testing with the valve that is almost completed. Have to wait for some hose and a tap to arrive in the post.
Next on the list is a pump. Can anyone help me with the gear sizes of the smaller end pumps? OD and H. What RPM are the gear pumps run at?
Old 08-05-2012, 02:51 PM
Madda Madda is offline
I will keep an eye on this thread, good luck with your project!
What mill are you using?
Old 08-06-2012, 04:06 PM
Hi, I'm using a Optimum BF20 vario mill
Old 08-07-2012, 12:53 AM
gear size 10mm
thickness approx 3mm
rpm upwards of 6000
10 to 15 bar
Old 08-04-2013, 10:24 PM
Hi, can anyone help me with what a "realistic" speed of a 14.5:1 bulldozer should move at in meters/min or feet/min. I will start a new thread of the build under construction equipment soon but will keep this one for random tech questions
