Old 08-20-2012, 12:10 PM
Default Radio transmitter and receiver
Hi Guys,
Can anybody help me i've recently brought a wedico cat 996g loading shovel i have put a 6 channel receiver in the unit but i'm using a model 2 {throttle left for planes} transmitter, my question is do i have to change over any of the servos in the receiver so that it works normally.
Any help gratefully received
Old 08-20-2012, 05:42 PM
carp carp is offline
Default Re: Radio transmitter and receiver
Hi, it should work normally plug your throttle esc into channel 3, what radio do you have? if its airplane then does it have a ratchet on the throttle stick?
Old 08-21-2012, 02:19 AM
Hi carp,
I'm using a Saturn 2.4 ghz 6 channel receiver/ transmitter and it does have a ratchet on the throttle stick ( left hand side)
Thank you
Old 08-22-2012, 03:05 PM
so did you get it to work? or did you want a spring return on the throttle?
Old 08-24-2012, 12:56 PM
Hi carp not had chance to look at it as yet, I'll keep you posted
Old 09-05-2012, 01:49 PM
Hi carp I finally managed to get my new model out, yes the radio does work well still trying to work out ll the functions though.
Cheers
