Old 09-19-2012, 09:13 AM
DuelTruckDriver DuelTruckDriver is offline
DuelTruckDriver is on a distinguished road
Default Glues for Alum/brass etc..
Hey guys I'm starting a new project and the truck cab is made of aluminum. What kind of glues will hold styrene to aluminum? And brass to styrene maybe? Thanks for the help guys much appreciated. >Marty<
"You play meat?"
Old 09-19-2012, 12:22 PM
Default Re: Glues for Alum/brass etc..
Epoxies and CAs(super glues) should work but I would try them on scrap material before good parts. Make sure you degrease the surfaces which includes fingerprints!! Also roughen up the mating surfaces some so that the glues have something to adhere to.
LYNN
Old 09-20-2012, 07:46 AM
there are a lot of body shop glues that do that like a weld I use LORD Fusor 143 works great you would have to break or bend the parts to even get a chance to get them apart if you could.
Old 09-20-2012, 11:42 AM
Madda Madda is offline
I use this for connecting steel and aluminium parts together: http://solutions.3m.com/wps/portal/3...poxy-Adhesives
There are two chances: it won't glue anything and you did something wrong or it will glue pieces together so hard that it is almost impossible to remove them again. Only heat will help then.
Old 09-22-2012, 03:04 PM
MACK Daddy's Avatar
JB weld works for me when needed..Or a two part epoxy mix as well....Both can be gotten at a local Home depot
Alfy
Old 09-23-2012, 09:39 AM
kerst's Avatar
kerst kerst is offline
Very true! I usually degrease my fingers as well!
I use this supplier: http://stores.ebay.com/polymerproducts
And I am very happy with the results.
Kerst
