Old 08-13-2010, 11:08 PM
Default Cutting up a cab
Here are 2 videos of me cutting up a cab with a table saw.
Good luck and watch your fingers.
Travis Biddle
Old 08-14-2010, 07:08 PM
FreddyGearDrive's Avatar
Default
Ever since you showed this in the spring.It's my prefered method of making cuts. Nice tip!
FGD
Old 08-15-2010, 03:01 PM
Default Re: Cutting up a cab
I can't bring myself to try this method! Something about a table saw just makes me break out in cold sweats! Quess, I will still use the trusty band saw until I get up the nerve.
Old 08-16-2010, 12:15 PM
This is a nice Idea Travis. Ed
Old 08-16-2010, 05:49 PM
Travis - this makes my mehtod - Hacksaw - look really stupid.
- do you set the blade height tall enough for the material - then go back and clean up the radius corners - or full thickness - any issues with aligning the cuts on non square surfaces??
Old 08-21-2010, 09:17 PM
Hos1880's Avatar
Hos1880 Hos1880 is offline
Hos1880 will become famous soon enoughHos1880 will become famous soon enough
Travis what blade do you use?
Merritt
Member of Central Plains Mini Truckers and Certified Army Nut
Old 08-22-2010, 10:44 PM
russisloud
Guest
Posts: n/a
wow, thats more guts then i have! i'll stick with my band saw
Old 08-22-2010, 11:30 PM
There's also the string method which you can align each end of the cut, then draw the string back and forth between the two points. Use some string line or good nylon string. I've never tried it on RC bodies but have used it to cut PVC pipe, although alot of people on Scale4x4 have used it with success.
You must have a better table saw than the cheap one I had a few years ago, my gate was never paralell to the blade, I had to square it off and clamp it.
Old 08-23-2010, 03:46 PM
Bodyman Bodyman is offline
Bodyman is on a distinguished road
travis, how many tooth blade. do you put blade backwards like when you cut
vinyl siding?
nice to meet you at indy
steve
Old 08-23-2010, 07:14 PM
The blade is in the normal direction and I think it is a 120 tooth. I tried the string method and it sucked for me I did more damage than good so I think I will stick with the table saw and the score and break method. I also use the small hand saws from ZONA they are great I have had mine for 2 years and have cut a lot of styrene and alumium with it and it is still sharp.
Old 08-28-2010, 09:38 PM
FabOne's Avatar
FabOne FabOne is offline
4 fingers later, I think I've got it down (LOL)!
FabOne
NW Ohio
Old 08-29-2010, 12:29 AM
cummingsman29's Avatar
Lol, I have used a razor knife and hand saws to cut up cabs works well.
DONNY
EAST COAST MINI TRUCKERS
Old 09-02-2010, 06:18 PM
Diesel Demond's Avatar
must have big @%ts!
Old 09-04-2010, 08:08 PM
aussierolla's Avatar
aussierolla aussierolla is offline
aussierolla is on a distinguished road
Talking Re: Cutting up a cab
i want to give moding a cab but not really game enough yet but want to thank you for the tips
Old 09-04-2010, 08:24 PM
I would try a band saw but I don't have one or access to one so for now I will stick with the table saw and ZONA razor saw.
