Old 10-09-2012, 02:33 PM
Default Interesting MFU info
While working in a few things I discovered that with having a Trans servo installed but not connected to the Trans the mfu still cuts the rpm down do match what gear you are in... Kinda stumbled on it by accident but then got to thinking those of you hesitant on changing the Trans to a single gear Trans , or don't have the room for the stock Trans can still have 3 different gear speeds without actually shifting any gears... Figured id share the info as I know it'll help some of you out with custom builds that need more room. Can run your motor to a gru and still have 3 speeds without an actual Trans... How this helps someone out try it. Disconnect your Trans linkage then drive your truck and shift your gears you'll see.
