Old 09-20-2010, 09:31 AM
Snowman's Avatar
Snowman Snowman is offline
Default Nick's 379 build
Well, it's about time I shared with you guys what I have been building and how far I've got so far. So, without further ado, here's a brief resumé in pictures:
The start
Goodies
Mockup
Cab and hood ain't right for a pete, more chopping to do
Better.
Reshaped sleeper and mockup with rest of body and John's sweeeet stax
Nick
My Peterbilt build thread:
Old 09-20-2010, 10:10 AM
nenard's Avatar
nenard nenard is offline
Default Re: Nick's 379 build
Hot as blazez already! Very nice.
Old 09-20-2010, 05:35 PM
Snowman's Avatar
Thanks. I've learnt a lot about body filler and sanding. Done a lot of that. Had a few setbacks, pinholes in filler. Wasn't happy with the hood sides so chopped them out and made new panels.
Got a set of Brian's super steps to polish up and fit. Could anyone give me some advice on polishing aluminium? I've been wet sanding the steps to take off any marks, working through the grades. I have a dremel to polish with. Any tips on what speed to use? Is faster better or not?
Thanks!
Nick
Old 09-20-2010, 09:40 PM
Brian in PA's Avatar
I'd rather be truckin'
Nice pics Nick! Polishing aluminum is pretty easy if you got the right stuff. The dremal will work fine but you will eat up a lot of wheels. I recommend getting a small bench grinder and putting a set of buffing wheels on it. This will be your best bet for your larger parts.
Good luck!
Old 09-21-2010, 08:59 AM
sneaky-pete's Avatar
Master A-Modeler
The truck looks cool Nick,now hurry up with some more progress photo's
Troy
Old 09-22-2010, 06:46 AM
Snowman's Avatar
Thanks Brian for the tip, I'll be investing in a little bench grinder and buffing wheels soon.
Troy, just as soon as I finish the bodywork I'll post some more pics!
Next month I should have a bit more time to myself, my target is to finish the whole thing before the end of the year.
Nick
Old 10-05-2010, 09:57 AM
Snowman's Avatar
Quick update:
Tanks and steps are just sitting on the table, they will be mounted a couple of mm higher, and the lower cowl will be trimmed a few mm too. Been deliberating for ages just trying to get everything lined up but I think it's as near as it will ever be. Been working from photos so it can be quite tricky to get it right. Sitting on rims at the moment as I need to remove the lacquer to polish them up before trying to fit modified wedico tyres to simulate lo pros.
Nick
Old 10-05-2010, 02:10 PM
WoW!! this is a great update Nick! This brings a whole idea to low riders.
Old 10-05-2010, 07:49 PM
Stylin n profilin's Avatar
Stylin n profilin Stylin n profilin is offline
I'm tryin Boss!
Stylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura about
Awesome job Nick....That thing is sweet!! I cant wait to see this one done..
One Bus Stop Short Of The Short Bus...
Old 10-05-2010, 07:51 PM
Very nice going to be killer when it is done..
Old 10-06-2010, 11:23 AM
Master A-Modeler
Very cool,i love it!
You are going to have fun stretching those tires around the wheels!
Troy
Old 10-06-2010, 12:22 PM
Snowman's Avatar
Thanks Troy, actually I was gonna ask you if you have any tips for fitting those tyres, did you trim them at all?
Brian, I hadn't intended to build a lowrider from the outset, but it seems to have naturally gone that way! The cab work you did on your daycab convinced me to redo the windshield on mine. Really helps capture the pete look.
Brian, John, Mr Cowboy, Troy, you have all built trucks that have inspired this build so thanks for the kind words, means a lot, and thanks for sharing all your builds. Without all this information I wouldn't have got where I am now with my project.
Nick
Old 10-06-2010, 02:34 PM
Master A-Modeler
I will send you a pic of what I did w/explanation when I get home tonight.
Troy
Old 10-06-2010, 04:48 PM
Snowman's Avatar
Hey, thanks man!
Nick
Old 10-06-2010, 09:01 PM
Master A-Modeler
Hey Nick,
This is how I fit the wedico tires to my meir wheels.
First I ground down the lips on the inside with my bench grinder(be careful not
to nick the outer rim).
In this pic,I cut off the long portion of the hub so I could use my hub covers.
Then I wet the tire to help slide it on (this helps when you are doing a bunch of
tires).
When you get the tire on the wheel it will be lop-sided.
You will need to work the tire around the wheel with your fingers.
Then you are done!
Troy
Old 10-06-2010, 09:12 PM
That looks great Troy. There is no mods to the tires?
Old 10-06-2010, 09:15 PM
Master A-Modeler
Sorry I forgot to mention that I did not modify the tires.
Troy
Old 10-07-2010, 12:33 AM
someone can also make wheels to fit he just did 2 tonight
Troy where you get those hub covers ?
looks good , Nick
IHSteve
Old 10-07-2010, 12:50 AM
you guys lost me here!
you have a king hauler with wedico rims and whos tires??
whats the reason for this setup
Old 10-07-2010, 01:00 AM
Nope, Meir wheels, Wedico tires, I believe they are going for the low-profile look.
