Old 11-15-2012, 10:43 AM
Stickman's Avatar
Stickman Stickman is offline
Stickman is on a distinguished road
Default MFU controls are backwards!?
I can't seem to get my MFU to function right. It steers and shifts fine, but the throttle and horns are backwards. When I move the left stick up/down it honks the horn. When I move the right stick up/down it controls the throttle. The side to side functions work like they should on the correct sticks. I have reprogrammed the MFU many times with the same results.
Left stick up/down right/left
Right stick up/down right left
The radio is a Futaba 4YF-2.4GHz if that helps. This is my first build, so I feal like I am missing something simple. Any ideas?
Old 11-15-2012, 11:09 AM
Default Re: MFU controls are backwards!?
Swap your support leg and throttle Ports on your receiver itself. So if throttle is in 3 and support in 1, put throttle in 1 and support in 3 see if that helps
Old 11-15-2012, 11:18 AM
Stickman's Avatar
Dude! That was it! Now I just need my driveshaft to come in and start driving. Thanks alot!
Old 06-17-2013, 03:11 PM
Hounddad Hounddad is offline
Hounddad is on a distinguished road
Holy guano, Bat Man!
I used the search function and actually found results that fixed my problem.
Thanks dabears.
