Old 11-16-2012, 07:46 PM
Dieselchopper's Avatar
Default 5488 IHC Snow Blade
I started building a snow blade for my recent purchase. I bought the tractor from Travis through the Buy and Sell on here. I am making most of it from steel. Here is the raw material picture. More to follow over the weekend.
http://
Old 11-17-2012, 12:43 AM
Default Re: 5488 IHC Snow Blade
http://
http://
Old 11-17-2012, 12:45 AM
http://
http://
Old 11-17-2012, 12:46 AM
Took it out for a test run. Works good as long as traction is maintained.
Old 11-19-2012, 03:28 AM
Seems to work well...
Wer use sawdust for pushing silage.
regards,
Frank
Old 11-19-2012, 10:03 AM
Looks good and solid!
Old 11-19-2012, 10:26 AM
Blade looks good! Did you make a video with it in use yet?
Old 11-19-2012, 06:25 PM
I built it all steel, will have a belly link to hitch at rear yet. Did a test run in snow. Had traction trouble. Was very good with dog toys on the living room carpet...lol. I have a very understanding wife. Will be trying the saw dust to see how we'll that works when I get some picked up. Videos will come after paint and all is done. Thanks for the kind comments.
Old 11-19-2012, 07:51 PM
Fill the rear tires with BBs and glue the tires to the rims, will help with traction. Mounting the hitch to the back is also a great idea, like the 1:1s. Could you turn the lifting servo on it's side so it's not so obvious? I wonder if you could turn it on it's side and mount it under the plate it is sitting on now? Just thoughts.
Old 11-19-2012, 09:48 PM
In Canada many field tractors have an extra fuel tank added so the unit can work all day without coming back to the yard for fuel. When finished I am going to have it look like the extra tank. The traction problem is due to the full differentials in the transmission and both axels. Start to spin anywhere and it's gone. Looking at locking up the axels to help. Can't lock up the tranny as the differential is needed to have both axels working.
Old 11-21-2012, 06:33 PM
I will look to see if I still have the diff locks for the axles. I took them out and put the diffs from a Mini LST2 in to make it more drivable. When on carpet with the diffs locked it hopped around a lot and was not much fun to drive.
Here is the Horizon Hobby part number for the axle dif locks. LOSB1434
Old 11-21-2012, 07:14 PM
Thanks Travis. Will wait to hear from you. If not will go looking.
Old 11-19-2012, 10:21 PM
Ah, didn't realize you were going for the auxiliary fuel tank look.
Old 11-20-2012, 07:06 PM
Lol....no worries hard to tell at this point. Still lots of clean up and then paint.
Old 11-20-2012, 11:36 PM
Have you considered using "shoe goo" in your rear diff. to make it a limited slip?
Old 11-21-2012, 09:05 AM
I'm curious, does this work like thicker grease, or will the glue dry?
We used to place thicker grease in differentials to make limited slip effect, curious how "shoe goo" type product would work.
Old 11-21-2012, 09:51 AM
Get ahold of LilGiants Joe for more info.
