Old 12-06-2012, 08:50 AM
Scottyboy436 Scottyboy436 is offline
Scottyboy436 is on a distinguished road
Default Which motor for screw lift?
Ive been looking for motors and ive found a 12v 60rpm motordoes anyone know if it would be good?
Old 12-06-2012, 06:29 PM
Cammo Cammo is offline
Cammo is on a distinguished road
Default Re: Which motor for screw lift?
Hi Scotty, it depends on a couple of things, I will try to help you work it out. The most important thing is what is the pitch (Distance between one thread and the next thread) of the thread you are driving. if say you use a M6.0 x 1.0 (6mm thread by 1.0mm pitch) then with a 60 RPM motor, you would 'screw' 60mm per minute. This is reasonably strong but slow.
I am currently running my screw dump trailer 12V @ 140RPM, on 7.2V NiCad, meaning I get 70 odd RPM and it is way to slow. I have now got a 150RPM at 6V which I think will be much better, just not sure about the strength.
Next this is how much throw you need on the thread to do what you want, and to work backwards to the RPM.
I realise I have rembled a bit, check out my screw drive http://www.youtube.com/watch?v=syoxV5SVbOc
Australian Heavy Haulage
"Keep on Truckin"
Old 12-07-2012, 05:13 PM
dmess62's Avatar
dmess62 dmess62 is offline
Hope this helps one post has a shopping list of items needed
http://rctruckandconstruction.com/showthread.php?t=5378
Thanks Dave
Dave
Old 12-08-2012, 01:32 PM
Thanks i will probably use that carson motor for there semi dump trailer and if its to slow ill just buy a new motor.
Dave i have been on that before but instead of using the thruster bearing im going to uss two nuts so it dosnt undo the bolt instead of lift the bed
Thanks scott
