Old 09-25-2010, 04:19 PM
Bigrigger's Avatar
Default Riding High
Hello RC builders! I'm wondering what sort of thing I should put in between the suspension and the axle to give it more ground clearence. Thanks!
Old 09-25-2010, 04:44 PM
Default Re: Riding High
What about longer spring hangers or some kind of bracket between the hangers and frame?
Old 09-26-2010, 08:09 AM
You can change the ride hieght by adding shims between the springs and axles but your ground clearance will not change unless you put bigger tires on. The ground clearance under the axles will remain the same until you do this.
Old 09-26-2010, 10:13 AM
Use f350 leaf springs you will get all kinds of lift this way and it is all bolt on..
Old 10-30-2010, 04:01 PM
Bigrigger's Avatar
Ok thanks guys, I meant ride height.
Old 11-04-2010, 07:47 AM
FreddyGearDrive's Avatar
Bend the springs.
FGD
