Old 12-27-2012, 07:29 PM
jazza's Avatar
jazza jazza is offline
jazza is on a distinguished road
Talking How to make hydraulic valve?
Can any once tell to me, How i can make hydraulic valve? or post assembly image of it.
Thank in advance.
Old 12-28-2012, 03:19 PM
Jw.'s Avatar
Jw. Jw. is offline
Jw. is on a distinguished road
Default Re: How to make hydraulic valve?
Hey Jazza check out Trucker47's thread on his loader. Page 4 and Page 5 has photos of his whole hydraulic setup he homemade.
http://www.rctruckandconstruction.co...ead.php?t=3260
Old 12-28-2012, 03:49 PM
That is much the same as what I have built. There are other styles out there too but this type(rotary) is quite common.
Reg
Old 12-28-2012, 05:11 PM
Jw.'s Avatar
Jw. Jw. is offline
Valves for our applications are normally fall under the 5/4 port 4 way 3 position setup. As in this picture below trying to explain the ports. Its of a spool valve to get backward and forward control of a hydraulic circuit. I recommend going with the rotary valves shown above. They have the same fluid control but tolerances are easier to obtain than a spool setup. Also I recommend a closed center position so your hydraulics will not creep. How you make each valve is up to you. Individual depending on your application or together on a manifold with pressure and return circuits built in like RCP57's really nice manifold set up.
Ps Pressure from your pump
Pr X2 Return circuit. Combined on a rotary valve. Seen on the above pictures.
Pa and PbYour lines to both sides of your cylinder.
Old 12-29-2012, 06:47 AM
jazza's Avatar
Thank you all answer, It's really help me.
Can any once post the rotary valve blue print?
sorry for my more question, I'm a newbie
Old 12-31-2012, 12:00 PM
cosworth34677's Avatar
i quite don't get the layout of that pic? i want to make my own vale too. and really having a time with all the hydraulic stuff, price and understanding (pulling hair out)
Old 12-31-2012, 02:58 PM
Jw.'s Avatar
Jw. Jw. is offline
Please excuse my poor cad abilities as I'm still trying to learn. This is the manifold I quickly drew up to help explain.
Old 12-31-2012, 03:36 PM
Looks pretty clear to me! Nice drawing.
Old 12-31-2012, 08:09 PM
Jw.'s Avatar
Jw. Jw. is offline
Thanks! I eventually will be attempting this myself at some point. What did you end up having as a diameter for your valves? I read through your thread and you ended up making them smaller than you original planned. It looks like your manifold is steel? Whats the valve body? Aluminum? Also what did you use for seals?
I spent some more time in cad came up with this.
Old 12-14-2016, 01:00 PM
Thank you so much. I looked all over the Internet for cheap hydraulics and I was supprised to see how expensive hydraulic valves are. Many places charged into the hundreds in Euro's just for a 2 way valve and the models I want to build need many more valves and components which weren't getting cheaper.
Old 12-15-2018, 07:16 PM
Cat966c Cat966c is offline
Could I use plastic for the valve rotor?
This thing:
File Type: jpg EEFCA28A-B90F-4522-8919-64A189444D6A.jpg (157 Bytes, 103 views)
Old 01-01-2013, 12:58 PM
Madda Madda is offline
Jw., good job on the drawings!
One thing that I'm not really sure of is where and what seals are used?
Old 01-01-2013, 01:45 PM
JW : steel or iron next to brass would be the best choice for your manifold . Aluminum does not wear well .
Madda : O-rings work well for the seals as you should only have to seal the shaft of the rotor and the rotor cap . between the rotor and the valve block , you should have a lapped fit .
Old 01-01-2013, 03:44 PM
I agree with Steve 100%. The valve that I made for my skidder is all aluminum with brass rotors but it may not last long. The valve block that my father in-law made for my EC300DL has a steel manifold and should last much longer. The shafts are sealed with common O rings on both. The EC300 runs at 30-35 bar with no leaks on the valve shafts.
Old 01-01-2013, 03:54 PM
This is the only picture that I took of the Volvo's valve assembley. I believe the pistons in this are .550. In mine they are slightly larger at .610.
Old 01-01-2013, 04:20 PM
even with the poor tolerances on the Robbie valves , they don't leak . The rotor just chews up the manifold . When I get back to running steel in the mill , I'll be making 2 , 1 for the loader and 1 for the TD40 .
Old 01-01-2013, 04:31 PM
so this is all steel? i want to try to make one of these, but i only can cut aluminum on the router table at work. can i use plastic on any parts? and why not aluminum? thanx for the thread guys lot of good info !!
Old 01-01-2013, 04:45 PM
The top of the valve in the last pic is aluminum but the bottom is steel. I think that aluminum is "ok" as long as your rotors are made of brass or steel. Aluminum rubbing on aluminum will gall up even with oil in there. Aluminum just wears quickly and won't maintain the tolerences needed for very long. Plastic would not be a good choice in my opinion.
Old 01-01-2013, 05:58 PM
so what if you put some kind of "buffer" between the Aluminum? like a brass thin shim or washer? of even a brass gasket? the only reason i ask because again i only have the abillaty (<---spelled wrong) to cnc aluminum? the cnc router at work will only route softer metals only because of our bits. and the boss won't let me cut steel on it i asked before for parts for my real car.
Old 01-01-2013, 06:19 PM
Finster's Avatar
Finster Finster is offline
Perhaps some automotive gasket material between the 2 main pieces would work?
Like: http://www.autozone.com/autozone/acc...erial/_/N-25w7
