Old 01-03-2013, 09:27 PM
buzzy16 buzzy16 is offline
Default Crushed rubber
So I dont know if this is the right place for this so if it isn't sorry.
But can someone tell me where I can buy crushed rubber, probably online seemings I live in Australia.
like this http://www.youtube.com/watch?v=kyhSH...1&feature=plcp
Old 01-04-2013, 05:20 AM
fuzzy fuzzy is offline
fuzzy is on a distinguished road
Default Re: Crushed rubber
i would check with your tire dealers to see where they send junk tires.
Old 01-04-2013, 07:07 AM
Snochaser's Avatar
Companies that install artificial turf use it to make the turf stand up and give it cushion. I got mine from a friend that installs it. If not check out granulated rubber in a search.
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 01-04-2013, 07:34 AM
i have worked dnr tire cleanup jobs in iowa. moved semi loads to Des Moines. that is where i got mine.
Old 01-04-2013, 07:46 PM
ryman's Avatar
ryman ryman is offline
I got mine from here:
http://www.flexground.com/color_and_design.html
Good luck
Riley
Old 01-06-2013, 01:38 AM
titandigs's Avatar
Aussie Fabricator
There is a place in Queensland that sells it in 20-40kg bags @ about $1.20 per kg. As the other guys have said try some companies that supply the soft finish in play grounds (same stuff)
