Old 01-20-2013, 04:55 PM
catmack catmack is offline
catmack is on a distinguished road
Default Track Parts
Ari,
Great work!...are the grousers aluminum?...this next question would be for anyone who wishes to reply, aluminum under carriage for no more than these machines are doing, seems to me okay at least for the excavator class, does everyone agree?
Colin
Old 01-20-2013, 05:06 PM
Default Re: CAT 374D L
Colin , yes, unless it's a kobelco bladerunner , all the excavator undercarriage does is get the machine where it needs to be .
Old 01-20-2013, 07:41 PM
ihbuilder,
Thanks for the response, that part I do understand, sorry for not asking a more direct question. I probably should have asked the question a bit differently...is everyone using aluminum undercarriages on their models, happy with the performance and are there any "wear issues"? I am guessing not on the pads, more curious about the rails, rollers etc.. Also, are aluminum undercarriage components on model dozers being used and successfully? Thanks, Colin
Old 01-20-2013, 08:09 PM
Many commercial kits are brass or steel rollers on steel pins, the tracks are either two piece steel or solid cast nylon.
Old 01-20-2013, 08:36 PM
big difference on the brass and steel, two piece track, is this the pad by itself (1) and the complete link unit (2)?...solid cast nylon?, is this working out well? seems like a good way to go on excavators at least and suppose it answers the alum. question if it is. Does this subject warrant it's own thread?
Old 01-21-2013, 03:35 AM
Default Re: Track Parts
This is the one piece nylon link that's on my 850 now.
Scale Art has a one piece cast metal link.
That's what can be bought for 14th scale. IHSteve has machined his own track parts in steel for his dozer. Other builders, like RCLogger use K1 attachment chain & bolt on their own selfmade pads. McMasterCarr, as well as others carry that chain in various sizes.
Old 01-21-2013, 04:05 AM
Colin , no prob . for a dozer , loader or any machine that will do a lot of traveling , I prefer to go all steel . From my point of view , aluminum under carriage on an excavator model is sufficient . Having said that , not just any grade aluminum . For my 2 I'm building , I'm using aluminum pads and links with real pins and bushing setup ,but I'm leaning toward everything else to be steel for the dead weight . Which will help with digging .
Old 01-21-2013, 05:26 AM
That's what can be bought for 14th scale. IHSteve has machined his own track parts in steel for his dozer. Other builders, like RCLogger use K1 attachment chain & bolt on their own selfmade pads. McMasterCarr, as well as others carry that chain in various sizes.[/QUOTE]
Do you know what the nylon makeup/compound is for the one piece molded ones?, it appears Liebherr models are using a zinc diecast.
Steve, I am with you on the difference in weight made up with ballast in other places of your own choice as it is key to getting the crowd loading effect at scale. I will post what I am working on as soon as it "comes off the press" and will bring it to Cabin Fever.
I appreciate the feedback so far. Colin
Colin
Old 01-21-2013, 06:02 AM
where you there last year ? I'd love to see that motor .
Old 01-21-2013, 06:49 AM
yes, been attending that show for many years.
Old 01-21-2013, 07:18 AM
then was that your cat motor I saw the 2 years I went ? I meet Steve in person in "10" my 1st year there . That was after he suggested I show my stuff off there . I would've brought it in had there been a better area to run it like we had in "11" "12" I missed "11" do to business issues . I'll at least have my 990 totally completed for this year . It works , I just need to finish the details . But considering it was just a frame.boom and bucket this time last year , it went together pretty quick . the dozer is iffy there's still a lot of drive function to do to operate .
Old 02-24-2013, 12:34 PM
dirtpusher9's Avatar
Moderator
Those look great Colin. I think your on the right track (no pun intended). The ones for the dozer look great.
The aluminum would be plenty for the trackhoes but for a dozer that gets a lot of work I would think steel would be the way to go, plus it would give more weight to the machine.
Old 03-05-2013, 06:43 PM
Yeah Joe,
It needs the weight to act like the full size. I am working on a sample link and will post when I have it finished or close to it.
