Old 01-23-2013, 02:00 AM
titandigs's Avatar
Aussie Fabricator
Smile Trommel made from left overs
Hi guys,
After seeing the fantastic Trommels on YouTube I thought I would give it a go with the leftover scraps in my shed.
Here are a couple of videos of the testing.
This is a work in progress/ prototype.
Any thoughts?
Paul
http://youtu.be/AzmcAvdUSK8
http://youtu.be/cplkz_r_iF4
http://youtu.be/iSBsDuOSW1Q
Old 01-23-2013, 03:00 AM
buzzy16 buzzy16 is offline
Default Re: Trommel made from left overs
Looks great, works well too, you've made good use of scraps.
Old 01-23-2013, 04:14 AM
The use of your Duratoy conveyer & hopper would be perfect to feed this trommel... then 3 bruder conveyers on the sides to fill trks with sized material.
Old 02-20-2013, 01:18 AM
titandigs's Avatar
Aussie Fabricator
Hey Joe, the Duratoy conveyor has arrived and I have fitted the drive motor I got from Servo City, I now need to make an infeed and finish the trailer to carry it, this sould be finished this week.
Old 01-23-2013, 08:14 PM
titandigs's Avatar
Aussie Fabricator
XLNT> That is great, Just at the right time too, been thinking of doing one but could not think how to do it. What did you use for the cylinder? Top job, 100 points.
I was looking for a screening plant but they are called Trommel, no wonder I could not find any information on them.
Cheers Chris
Thanks Chris, I made the drum from perforated metal and welded the seam.
Trommel translated is drum apparently
Paul
Old 01-23-2013, 08:18 PM
titandigs's Avatar
Aussie Fabricator
Hi Joe, I have another Duratoy conveyor on its way, should be here in a couple of weeks along with A separate conveyor belt assembly.
I will be looking at making new conveyors from Ali at the same size as the Bruder one to be able to use the belts.
Paul
Old 01-24-2013, 02:59 AM
Trommel is norwegian for drum.
Right on Paul, looking forward to seeing it all come together.
Old 01-24-2013, 08:32 AM
Great use of extra materials! Trommels are interesting to watch work and now you have a source of 1:14 mulch and bedding. So, where can you buy 1:14 scale landscaping plants? Really nice job on the build.
Old 01-24-2013, 03:35 PM
tracksntreadslou's Avatar
Great job on the trommel Paul..Sorts very good and very simple You could use some vibrating motors to help the material slide down the shoots ..I am currentley working on one myself and getting close to finishing..i will post some new picks on my thread
Old 01-25-2013, 01:26 AM
titandigs's Avatar
Aussie Fabricator
Smile Re: Trommel made from left overs
I will test it again over the weekend with the new shutes and hopefuly make an infeed shute and post the video. If it is slow in ejecting the material I will look at adding a vibration unit the same as I put on the Duratoy conveyor. Looking forward to see more of your build.
Paul
Old 01-28-2013, 12:40 AM
titandigs's Avatar
Aussie Fabricator
I got side tracked and thought I would give it a lick of paint and add some work lights.
Thanks for looking Paul
Old 02-20-2013, 02:16 AM
Good to see Paul.
Will you hang the trough/feeder spout from the conveyer? Can you purchase just the conveyer (what's shown) by itself? If so, much of a price reduction?
Looking forward to the video... 8 - 10mins, I wanna thoroughly see it work.
Old 02-20-2013, 02:39 AM
titandigs's Avatar
Aussie Fabricator
Good to see Paul.
Not sure, I was thinking to hang the trough from the trommel infeed end.
Hope to get a video soon.
Paul
Old 02-24-2013, 12:12 AM
titandigs's Avatar
Aussie Fabricator
Have done a little more today, still a lot to work out,(infeed speed, angle of shute????)
Here is the price list of all the available parts, if anyone would like contact details of the seller please send me a PM
Old 02-25-2013, 01:06 AM
titandigs's Avatar
Aussie Fabricator
I have found that if the in-feed angle is less than 45 the dirt has trouble moving down the shoot. On mine I didn't want to raise the the shoot and increase the angle so I added a couple of :bumps: on the drum. As it rotates it hits the bumps which sends vibrations through the unit which in turn shakes the stubborn dirt down into the drum. It also sounds a bit more "machine like" with a steady rhythm to it.
Hey Chris, I tried it yesterday and had the same issues, I tried the shute made from cardboard just for the test. I think I will try and find a couple of vibrating units from the MFU and mount them under the drum and on the out feed of the conveyor. I have used these on the hopper with great success.
Paul
Old 02-25-2013, 04:50 AM
Your drum speed might be too slow... my screener bucket spins at about 60rpm, I tip it a couple of degrees from level and the material comes quickly, even damp soil... get the lumps tumbling, that'll vibrate the drum & shake all the fines out. Your feeder trough, could line with puck board - very slippery plastic.
