Old 02-09-2013, 04:04 AM
Kaf343's Avatar
Kaf343 Kaf343 is offline
Default PMD 4:1 brand new split
Hey has anyone ever had this happen, I just noticed it on one of my pics. It has not even ran yet! Any thoughts on repair or just get a new back case. Liquid steel epoxy?
Arrgggg
Old 02-09-2013, 04:10 AM
Default Re: PMD 4:1 brand new split
I would call up Ric after u send an e-mail with the pics.
Old 02-09-2013, 04:25 AM
I'm sure Ric will make it right for you Keith. The sad part is the postal system and the time lost waiting for parts kinda puts the build on hold eh?
Mario
Old 02-09-2013, 08:39 AM
Is that the bearing we can see, behind the driveshaft yoke, or part of the box which broke off? It's got some vise looking marks on it too. I'm sure Ric will hook you up with a new one.
Old 02-09-2013, 12:41 PM
Keith - your first line of communication should be with the vendor - not spittin nails to the general public. Ric will clear this up with you.
Does your drive line have enough slide distance? There really shouldn't be any pressure on that case to pull the bearing out. I can't tell - but I hope you don't have a fixed length drive shaft between your axel and the transfer case.
Izzy
Old 02-09-2013, 06:30 PM
Kaf343's Avatar
Yeah, I'm going to call Ric on Monday and send a pic to him.
Mario
I've got a few other projects going so down time on this one won't hurt.
That's the bearing housing next to the driveshaft. Yeah I'll call Ric.
Izzy
Izzy, not spitting nails anywhere. I was simply asking opinions from you guys who have far more experience than I. And I thought this was the place to do it. I'm sure Ric will help me out in what ever way he can.
The drive shaft has about 3/8" of slide, but it is between two fixed points. The 4:1 and a frame mounted carrier bearing. The second drive shaft between the carrier bearing and first axle is also adjustable. The bearing is still in place in the housing, it's the housing itself that is broke.
Old 02-09-2013, 07:55 PM
hmm looking at the machine marks , I'm wondering how that was made the face milling marks go right through where the bearing boss is
Old 02-09-2013, 09:41 PM
scalelover's Avatar
I was wondering the same thing. The scribes weren't making any sense at all to me, I just thought he may have brushed it afterwards. But looking again they are def face mill markings,they start shifting from straight lines to the radius of the cap near the top but the right side looks like they go right into it so I have no clue either.
Ric should be able to take care of you, that def looks like a defect in the casing itself, not from the driveshaft or coupler. Keep us updated
--Dan
Old 02-10-2013, 06:04 AM
Kaf343's Avatar
--Dan
Let me also add that I am sure that this is caused by something I did, I am not insinuating that the 4:1 is a poor design or anything else. I am never one to go back to the manufacturer first, I always will try to fix it my self first. Especially by me assuming that I caused the failed to start with.
Ric is a great guy and his products are industry standard, I have met him a few times and have spoke to him more times in the past few months than I can count. Ric has always took the time to discuss, explain or just talk with or about anything I was purchasing from him.
Here are a few closer shots of it apart for the machinist out there, I will talk to Ric on Monday but my first question is still does anyone think I can repair this without machining?
Old 02-10-2013, 10:27 AM
scalelover's Avatar
Kaf, I wasn't trying to say it was a badly designed part I was just wondering how he did the final machining. Te first pics it was hard to see the full radius of the bearing and it looked as if he may have gone right into the cap or just machined straight down around it. With the angled pics I can see a lot better how it was done and it makes sense because you can see how it was machined around the bearing cap, and not straight down or right into it.
As for repairing it, IMO I'd say it probably wouldn't hold up unless its welded. The side load from the output spinning and the force (even though its not a lot) that's put on the bearing is prob enough that any type of epoxy or aluminum weld putty may hold up for a short period, but it would probably just rip apart again. If your really good at welding you could do that and it would be fine as long as its lined up accurately.but again being such a small piece that won't be an easy task to do.i don't really see any other way myself, maybe a more seasoned machinist would know better.
--Dan
Old 02-10-2013, 10:44 AM
Kaf343's Avatar
Kaf, I wasn't trying to say it was a badly designed part I was just wondering how he did the finished machining. With the angled pics I can see a lot better how it was done and it makes sense because you can see how it was machined around the bearing cap, and not straight into it.
As for repairing it, IMO I'd say it probably wouldn't hold up unless its welded. The force that's put on the bearing is prob enough that any type of epoxy or aluminum weld putty may hold up for a short period, but it would probably just rip apart again. If your really good at welding you could do that and it would be fine as long as its lined up accurately.but again being such a small piece that won't be an easy task to do.i don't really see any other way myself, maybe a more seasoned machinist would know better.
--Dan
Dan,
Thanks for the input. I appreciate it.
Old 02-10-2013, 11:07 AM
OK this final pick says a lot - they just took a little too much away from the bearing cap - a nice fillet would have been prime. Un fortunately the bearing is actaly outside the case for the most part. - I suppose you could take a new plate, machine in a countersink to hold the bearing and then bolt to the outer of the existing housing - in all it would look like crap though.
I think Dn's idea of welding ot back together is best - really thin material though - it would be difficult even for an experienced welder.
I know this sounds bad - but what about some 2 part epoxy like JB weld - you could pretty much lay a nice fillet around the housing and the bearing cup.
Izzy
Old 02-10-2013, 11:58 AM
It's definitely a defect. Simply put, the milling process removed to much material around the boss. I wouldn't even try fixing it. Just be honest and show Ric the photos. I'm sure he'll take care of you.
Welding or JB weld is not going to be the answer. Even if you do pull that off, the shaft alignment could easily be off, and that will cause other problems.
Old 02-10-2013, 12:16 PM
I'm gona stick my neck out here and my $.02 now that I see better pics I see a small design flaw. To much material is removed from the bearing bore on the out side of the case . could be fixed real easy withe a simple tool change in the machining process with a .125" radi around the bearing bore or don't go so deep on the counter bore . I wouldn't trust any glues or welding in that area it's to critical for alignment . send for a replacement .
Old 02-10-2013, 01:38 PM
I'm pretty sure that welding it would just warp the bearing bore and it would no longer fit without remachining it. Much easier to get a new piece in my opinion.
Old 02-10-2013, 03:25 PM
scalelover's Avatar
Welding is def a last option because its such a critical alignment and so thin you'd have to be a super experienced welder to get it aligned correctly and not burn through it.
As IH said earlier I think it was machined to thin as well but didn't want to put my neck out there, seeing as I'm still a novice machinist compared to him but if he says so then I'd have to agree, for the reasons I mentioned in the earlier post about the force that's put on it. it id not a ton but enough that I'd have left a thicker base area right at the plate itself if not the entire bearing cap to avoid fatiguing the metal.
--Dan
Old 02-10-2013, 03:59 PM
Definitely a defect in machining, just as Steve described it -> free replacement shipping included, nothing but!!!
Let us know how it turns out for you.
Old 02-10-2013, 05:13 PM
Kaf343's Avatar
Izzy
--Dan
OK, so the consensus is don't try to fix it. Replace the housing. I'll talk to Ric tomorrow and see how it goes. Thanks for all the input and information.
Old 02-11-2013, 04:42 AM
Kaf343's Avatar
I just spoke to Ric and as everyone said, no problem. Send it in and he will replace it as soon as he gets new cases. Thanks again for everyone's input.
