Old 03-03-2013, 12:39 AM
Newcastle's Avatar
Newcastle Newcastle is offline
Newcastle is on a distinguished road
Default Solidworks help... Track pad
I have started using solidworks, and I am trying to design a track pad. I have extruded this picture so far, but now I dont know how to cut out pieces for the chain links or add bolt holes. Can anyone help?
Old 03-03-2013, 06:14 AM
pugs pugs is offline
Default Re: Solidworks help... Track pad
Select a face to put cuts or bosses on and then click the view normal to button (looks like an upward arrow with a wide flat base. Then click on new sketch, draw the shape, then cut or boss it up. If there is no flat surface where you need to build a new sketch then you will have to build a new construction plane through one of several methods, all are pretty self explanatory.
Jeff
Old 03-03-2013, 03:37 PM
PrimeRigg PrimeRigg is offline
PrimeRigg is on a distinguished road
If that doesn't help, go to youtube and look up solidworks tutorials.
Old 03-03-2013, 04:24 PM
Newcastle's Avatar
Worked a treat. Thanks mate :-). I have looked at a lot if tutorials. I am learning as I go slow and steady :-)
Old 03-03-2013, 05:22 PM
cdm cdm is offline
Bolt/screw/hole wizard in SW is pretty easy to work with
hang on let me get it started for a screenshot
right up there. you generally want to define it prior however.
you can also make threaded holes, through holes, limited depth holes, countersinks, hex cap holes etc. i suggest you keep like holes in groups, apply them when and where then place by clicking checkmark.
looking at your pad it looks like you got the hang of it quite well
Old 03-04-2013, 01:33 AM
Newcastle's Avatar
Ok, so this is where I am up to, I have to re align the hles on the track pad to fit the chain link better, but I am having a lot of fun with this process. Oh and this is for a D11 that I am designing. That hole wizard is great. I just had a go of it and it makes things a breeze.
Any tips are very helpful thanks guys.
Old 03-04-2013, 02:06 AM
D8R D8R is offline
This is my way of doing it!
Splitted parts, 3/4/5mm steel plates
Together
Made (silverbrazed together)
Dan
Old 03-04-2013, 12:57 PM
Newcastle's Avatar
I am considering placing nut retainer spaces in my chain links. It is a little tricky though because the links are so small. Can you get away with doing alloy track pads and chain links? Or do you recommend steel?
Old 03-04-2013, 01:29 PM
cdm cdm is offline
2024 alloy should suffice
Old 03-05-2013, 12:20 AM
Newcastle's Avatar
So this is my tracks with the pins in. They will use an M3 bolt through the track pad and in to the threaded chain link, the chain link pin will be clamped in by the two chain links. I just wish I could some how put in nut retainers for more realism.
Old 03-05-2013, 06:40 AM
cdm cdm is offline
you could if you go down to m2 10.9 or 8.8 steel bolts will hold. the problem is the threads will probably get caked in/rust and seize during future disassembly; same for m3 though
else circlips like everyone else does (i hate assembling these things though lol)
i actually love your idea of using the pad to clamp the pin from both sides....
Old 03-05-2013, 12:40 AM
Newcastle's Avatar
I think I may have to start a build thread in construction equipment now. Lol
Old 03-05-2013, 01:37 AM
D8R D8R is offline
If I'm not wrong you should have the pad turned around. The grooser(?) should be on where chain is as wide as possible.
/Dan
Old 03-05-2013, 01:42 AM
Newcastle's Avatar
/Dan
I'm not quite sure what you mean mate. Can u possibly show me an example?
Old 03-05-2013, 01:02 PM
Newcastle's Avatar
If I use m2 bolts I could probably fit in nut retainer holes. Do you know a website that does high tensile bolts that small?
Old 03-05-2013, 04:42 PM
cdm cdm is offline
i use mcmaster carr
http://www.mcmaster.com/#screws/=lr4my2
i just wish they had binding posts in metric tho.
Old 03-05-2013, 05:09 PM
Newcastle's Avatar
Originally Posted by cdm View Post
i use mcmaster carr
I got locked out from this site for doing abnormal searches. Lol. Fail.
Old 03-06-2013, 01:40 PM
cdm cdm is offline
hah thats a first.
Old 03-05-2013, 04:59 PM
Newcastle's Avatar
Also where I work ATM building a lot of stuff for the mines we just out lanolin grease on the bolts and it keeps them pretty much rust free.
Old 03-05-2013, 09:56 PM
D8R D8R is offline
Well grooser is the wrong word,mean the high comb or flange on plate, this end should be where shoes are wider, please look in this vid at 10sek, if you stop you will see what I mean.
http://www.youtube.com/watch?v=mfkprEuFg6o
Not to be picky, only trying to help, position this or that way will not effect the amount of work, only giving a result like the proto.
Dan
