Old 03-11-2013, 11:22 AM
Default Speed controller
Hi guys,
Can anybody help me with the difference with a brushed and a brushless speed controller? What's the difference and how does this affect a brushed motor?
Thank you
Old 03-11-2013, 07:41 PM
CG Bob's Avatar
CG Bob CG Bob is offline
Default Re: Speed controller
A brushed ESC has two wires connecting it to a brushed motor. A brushless ESC has three wires connecting it to a brushless motor. Generally brushed systems are cheaper; but brushless systems are more efficient.
Did a search for "difference between radio control brushed and brushless motors" and got lots of info. Here's one of the better explanations I found.
Old 03-11-2013, 08:49 PM
I'm going to make a bit a blanket statement here, but generally speaking most brushless speed controllers, cannot run a brushed motor, however there are some exceptions to that rule. Electronic speed controllers offered by Tekin, Castle Creations, and some of Novak's older ESCs are able to run either brushed or brushless motors. You just have to be sure that the one you buy can run either, if that is really what you want.
If you never plan to run a brushless motor, then there is no benefit to buying an electronic speed controller that can do either.
Speed controllers that are for brushed motors cannot run a brushless motor at all. They do not have the circuitry required. I would take a guess and say less then a quarter of the brushless speed controllers offered today are able to run brushed motors. Normally people do not mix and match brushless speed controllers with brushed motors. It's usually a brushless motor that people run with a brushless speed controller.
Old 03-11-2013, 10:17 PM
Hi guys,
Thank you for your answers what your both saying makes perfect sence.
Thank you
