Old 03-27-2013, 07:05 PM
farmhauler farmhauler is offline
farmhauler is on a distinguished road
Default servo turns all the way left and does not center
As soon as I plugged in the battery and turned on the receiver and transmitter, my shifting servo went all the to the left and will not center itself. I tried taking the horn off and it did the same thing. Any suggestions?
Old 03-27-2013, 08:17 PM
Default Re: servo turns all the way left and does not center
will it move when you move the sticks on the radio? if so it may be centering itself when powering on?
Make sure your trims are set to 0 and centered and not on a switch for testing purposes
Old 03-27-2013, 08:25 PM
when i move the stick on the radio it changes the sound of the buzzing of the servo. I think it is shot, i have tried putting the trims to 0 and everything. it is a cheap standard servo so that might just be it
Old 03-27-2013, 10:05 PM
Sounds like the potentiometer is not being driven by the output shaft of the servo anymore. If the potentiometer is not centered, the servo is going to move the direction it thinks it needs to, to satisfy what the potentiometer feedback is telling the servo.
If you can turn the servo shaft, with the power off, both directions, to it's hard stop, and everytime you turn the power on and it moves the same direction, then I would disassemble the servo and check to see if the gears and pot are all right. Might be an easy fix.
Old 03-28-2013, 07:29 AM
i disassembled it and all of the gears seem to be in good condition...and no broken solders or loose connections.
Old 03-28-2013, 07:48 AM
potentiometer is my guess to. not sure how to fix that. might be cheaper and easier on the hair line to get a new one. or buy a nice big strong steering servo and upgrade lol
Old 03-28-2013, 08:05 AM
Ya im thinking i may have to bite the bullet and get a better quality one for shifting. I have a heavy duty Futaba for steering and it works perfectly so i might just throw that one in there
