Old 04-14-2013, 08:24 PM
cosworth34677's Avatar
Default help! striped motor hole!!
arge!! help pleas! i just stripped the threads on the hole that on motor! the one that srews it to my pump! now i can't tight that side down. i tooke it apart to figure out what was leaking and now after try to tighten it down i stripped out the hole. any way to fix it with out destroying the pump or motor?
Old 04-14-2013, 09:33 PM
Default Re: help! striped motor hole!!
If I'm reading you correctly, you stripped the threaded hole on the motor? Short of drilling and tapping the holes to the next size up, I'd say there is no easy fix. Even that would be unlikely, as the holes in the motor cans are extruded, so drilling to the next size up may not leave enough material to cut the new threads anyway. Then you'd have to drill the hole in the pump larger too. Just get a new motor.
Old 04-14-2013, 09:36 PM
Wow, that must be the new English.
Old 04-14-2013, 09:55 PM
ya dude i suck at type and grammar i'd be the first on to tell you i stink at try say what i mean by typing it out, im more of look at this problem i made type more then writing it down or typing it out ...but that's not the important part
Old 04-14-2013, 10:57 PM
Gotta agree with espeefan.
In a situation like this, where you have a significant casing that the motor is mounted to, its probably both easier and safer to just replace the motor than try to repair the stripped mount hole.
Think about it - if the repair cuts loose, that gear moves in the pump casing, and oops, there goes the pump. OW, thats gonna hurt (plus metal fragments in your valves/line, doh!)
If replacing the motor is that expensive, you might try a braced-mounting for pump-casing and motor, where you can clamp/strap the pump down to the brace, mount the motor with the single screw, and then clamp/strap the motor in place. One of the machinists here could make you the mount.
But I sill think replacing the motor is both the safest for the pump, and cheapest/easiest for the assembly as a whole.
WhiteWolf
Old 04-14-2013, 11:02 PM
Newcastle's Avatar
Newcastle Newcastle is offline
Newcastle is on a distinguished road
You could always put a helicoil in if you have room.
Old 04-15-2013, 02:06 AM
kingbob kingbob is offline
Most standard 540 size motors have 2 holes on each side. If one is stripped you might be able to just rotate the motor can to use the alternate holes.
Old 04-15-2013, 06:15 AM
its smaller the 540 im thinking its a 360 motor.... i think or a 380? don't know witch size is right.
Old 04-15-2013, 08:34 AM
cdm cdm is offline
yes there are 4 holes. 2 pairs. just spin it to the next set or change the 2$ motor
it is a mabuchi 540 size, 380 is unmistakenly smaller.
i thought you stripped the screwhead and couldnt remove it (that's bad).
The waiting games are real.
Old 04-15-2013, 10:27 AM
Its smaller then 540 . Its likt more 1/18 scale car size so I'm thinking its more360 or 480 . Is there a wau to tell ? I don't want to order thr wrong thing because I may replace it with a brushless
Old 04-15-2013, 02:38 PM
cdm cdm is offline
ah you have the gomez unit. i was thinking something else
measure the diameter. 540 is 34-36mm
380 is around 27
